Gen 2 ram (94-02) radio in a 78 d150?
#2497763
05/19/18 01:01 AM
05/19/18 01:01 AM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Anyone done this? Any tips?
Is it plug and play?
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Gen 2 ram (94-02) radio in a 78 d150?
[Re: dodge turbo]
#2497818
05/19/18 11:19 AM
05/19/18 11:19 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I would try it as long as the square face has opposing corner mounting lugs. Some don't. I know you will have to update the wiring/connectors etc from the old 78 dash stuff. I think the radios in ram full size trucks were square faced until 2002 model.
[Re: dodge turbo]
#2498463
05/21/18 12:32 AM
05/21/18 12:32 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Back when I helped a friend build competition stereo systems, we always used the chrysler style wiring harness/plugs. It's petty easy to find the wiring diagram online. I'd just run new speaker wire, but you could use the existing wiring also. You'll have a constant power, remote power/switched, ground then the 4 speaker wires... they are same color per speaker with a tracer. Really not much different than installing an aftermarket head unit.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
