Re: priming a 383
[Re: Smoparmike]
#2496391
05/15/18 12:12 PM
05/15/18 12:12 PM
RapidRobert
preoil at TDC #6 compression (zero on the tab) then turn the dampener back CW 3/4 of a turn (to #8 TDC) & preoil again & get (to) that point by cutting a strip of paper 17.082" & use it as ruler around the dampener. EDIT meant to say CCW
Re: priming a 383
[Re: Smoparmike]
#2496399
05/15/18 12:29 PM
05/15/18 12:29 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm lower tech than that.
I turn the motor over a few degrees at a time while running the drill. After I get oil coming out of the rockers on the first side, I put that valve cover on......then keep priming and turning until it flows from the other side. Put that valve cover on...... Done.
Re: priming a 383
[Re: Cab_Burge]
#2496418
05/15/18 01:14 PM
05/15/18 01:14 PM
RapidRobert
that way you get all the rods oiled on motors that don't have full groove main bearings I learned something today
Re: priming a 383
[Re: Smoparmike]
#2496911
05/16/18 06:32 PM
05/16/18 06:32 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Spinning it w/ the starter defeats the purpose of priming the oiling system. The whole idea is to get oil where it needs to be without spinning anything...then crank it.
Re: priming a 383
[Re: fast68plymouth]
#2497022
05/17/18 12:14 AM
05/17/18 12:14 AM
Posts: 30,998 Oregon
AndyF
I turn the motor over a few degrees at a time while running the drill. After I get oil coming out of the rockers on the first side, I put that valve cover on......then keep priming and turning until it flows from the other side. Put that valve cover on...... Done. From what I've seen everyone drills the oil holes in the same exact location so you can just crank then engine over to TDC on #6 and that oils one side. Then you have to spin it until the next oil hole comes around and that oils the other side. Every engine I've ever done has worked that way so all of the cam cores must be drilled the same.
Re: priming a 383
[Re: RapidRobert]
#2497129
05/17/18 11:03 AM
05/17/18 11:03 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I want to make a note of this for future reference ... I think you meant to say turn back (CCW) 3/4 of a turn on the crank to get to compression stroke on #8. Going CW for 3/4 turn on the crank (270 degrees) from TDC #6 would bring you to TDC on #2. Or am I missing something? Good info if you are oiling the rockers using the timing port drilled through the camshaft journal.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: priming a 383
[Re: an8sec70cuda]
#2497156
05/17/18 12:34 PM
05/17/18 12:34 PM
fast68plymouth
So. Burlington, Vt.
Exactly.
Re: priming a 383
[Re: rumblefish72]
#2497159
05/17/18 12:45 PM
05/17/18 12:45 PM
RapidRobert
I want to make a note of this for future reference ... I think you meant to say turn back (CCW) 3/4 of a turn on the crank to get to compression stroke on #8. Correct
Re: priming a 383
[Re: merpar]
#2497657
05/18/18 07:42 PM
05/18/18 07:42 PM
RapidRobert
My next I am gonna leave the (shortblock) #8 piston at TDC then when together preoil then go CW 3/4 turn to TDC on the tab & preoil again then back up slightly to 15 BTDC & set/time the intergear/dist with the rotor under #6.
