is there a mopar manual steering rebuild kit? #2496140
05/14/18 08:13 PM
05/14/18 08:13 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
My 1970 Cuda manual steering box has a slow drip and I hate that. Does anyone make a rebuild kit for a manual steering gear box? I see them for the power units but not for manual. If not, how do you fix it short of buying a rebuilt unit? Thanks
Re: is there a mopar manual steering rebuild kit? [Re: gregok] #2496152
05/14/18 08:41 PM
05/14/18 08:41 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I believe the gears in a 1970 manual steering box are greased. There is no fluid needed if greased properly.
Re: is there a mopar manual steering rebuild kit? [Re: gregok] #2496189
05/14/18 09:57 PM
05/14/18 09:57 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Firm feel sells rebuild kits
Re: is there a mopar manual steering rebuild kit? [Re: jake4cars] #2496218
05/14/18 11:35 PM
05/14/18 11:35 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Okay, thats what I am looking for. Thanks.
Re: is there a mopar manual steering rebuild kit? [Re: gregok] #2496442
05/15/18 01:58 PM
05/15/18 01:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The seals are "off the shelf" items at any bearing supply place. I don't think anyone makes the top gasket.
Re: is there a mopar manual steering rebuild kit? [Re: gregok] #2497026
05/17/18 12:18 AM
05/17/18 12:18 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I'm pretty sure I bought the paper seal for the 'top' from Firmfeel or mancini.
The drip is fairly common over time. The oil you see is probably a portion that has seperated from the other components of the grease. When you replace with fresh grease that will help as much as any seals. Yes, sometimes in service the grease will be topped off with some fresh oil. Of course that doesn't mix in perfectly and some makes its way to the bottom of the sector gear shaft.
Re: is there a mopar manual steering rebuild kit? [Re: Mattax] #2497039
05/17/18 12:37 AM
05/17/18 12:37 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I contacted Firm Feel and I purchased a seal/gasket kit from them. Thanks for the all the help.
Re: is there a mopar manual steering rebuild kit? [Re: gregok] #2497569
05/18/18 03:05 PM
05/18/18 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The drip is more likely a worn seal than oil separation. Let's face it, the steering box see's a lot of use and the bottom seal is well exposed to dust, water, etc..
Re: is there a mopar manual steering rebuild kit? [Re: Stanton] #2497731
05/18/18 11:13 PM
05/18/18 11:13 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
We will find out after rebuild.
