Cheap Valve Covers for Isky Rocker Clearance? Big Block
#2495161
05/12/18 04:07 PM
05/12/18 04:07 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I have Isky rockers on my 440 & I stupidly cut out the baffles to clear the rocker arm adjusters. Does anyone know where I can find some inexpensive valve covers (with baffles) to clear these rockers? I'm sucking oil through the PCV now THANK YOU!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block
[Re: R/T1968R/T]
#2495270
05/12/18 09:18 PM
05/12/18 09:18 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Unfortunately, I don't have a picture. They are on the insured/running/licensed car now & I was "hoping" not to take apart the engine until I had solved the problem and had the parts in-hand to put it back together immediately.
The valve covers are stock 1970 & the adjuster are the ones that came with the Isky rockers arms when I bought them new in about 1985 if that helps.
[Re: PurpleBeeper]
#2495594
05/13/18 04:47 PM
05/13/18 04:47 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
My buddy had a similar problem. We used a push-in breather with a nipple on it and added a short length of rubber hose to the nipple. The PCV valve then plugged into the short hose.
It doesn't look bad, and it worked like a charm.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
