Cheap Valve Covers for Isky Rocker Clearance? Big Block #2495161
05/12/18 04:07 PM
05/12/18 04:07 PM
Chicago
PurpleBeeper Offline OP
Chicago
I have Isky rockers on my 440 & I stupidly cut out the baffles to clear the rocker arm adjusters. Does anyone know where I can find some inexpensive valve covers (with baffles) to clear these rockers? I'm sucking oil through the PCV now frown THANK YOU!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495263
05/12/18 09:13 PM
05/12/18 09:13 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I have Iskys on mine with stock valve covers with no problems. There is a good chance you have the wrong length adjusting screw. Do you have a picture?
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: R/T1968R/T] #2495270
05/12/18 09:18 PM
05/12/18 09:18 PM
Chicago
Chicago
Unfortunately, I don't have a picture. They are on the insured/running/licensed car now & I was "hoping" not to take apart the engine until I had solved the problem and had the parts in-hand to put it back together immediately.
The valve covers are stock 1970 & the adjuster are the ones that came with the Isky rockers arms when I bought them new in about 1985 if that helps.
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495467
05/13/18 11:56 AM
05/13/18 11:56 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have used the Edelbrock steel covers with my Isky's for the same problem you have. They are about $55 from Summit or Mancini and are far superior to the factory ones.
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495594
05/13/18 04:47 PM
05/13/18 04:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My buddy had a similar problem. We used a push-in breather with a nipple on it and added a short length of rubber hose to the nipple. The PCV valve then plugged into the short hose.
It doesn't look bad, and it worked like a charm.
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495621
05/13/18 06:32 PM
05/13/18 06:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the summit chrome covers are taller and cheap. I use them without issue.
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495701
05/13/18 10:18 PM
05/13/18 10:18 PM
Chicago
Chicago
Hey Lee, do you mean these ones at summit listed as "stock height"?
https://www.summitracing.com/parts/edl-4493/overview/make/plymouth
Lew, do you mean these stamped Summit brand ones also listed as "stock height"? Do they clear Isky's or something similar?
https://www.summitracing.com/parts/sum-g3331/overview/make/plymouth
THANKS GUYS!
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: PurpleBeeper] #2495729
05/13/18 11:19 PM
05/13/18 11:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
THANKS GUYS!
that's the ones. they are noticeably taller than stock, are baffled, and made of heavier steel than factory. they're about 1/2"+ taller than stock. the only other alternative would be a tall cast alum; more $$$$.
Re: Cheap Valve Covers for Isky Rocker Clearance? Big Block [Re: lewtot184] #2495995
05/14/18 02:50 PM
05/14/18 02:50 PM
Chicago
Chicago
You da' man Lew
