Re: MSD Grid Ignition
[Re: rebel]
#2494775
05/11/18 02:47 PM
05/11/18 02:47 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I bought one two years ago and haven't used it yet I have had a NOS MSD digital seven non programmable box for several years also that I haven't used yet and called MSD tech to make sure the grid box is compatible with it, they said yes Now I have to learn on how to use the grid to do my tuning on the new car, whenever I get it done
[Re: rebel]
#2494796
05/11/18 03:37 PM
05/11/18 03:37 PM
Posts: 176 Sterling Heights, MI
John_T_Brown
Ok here goes, I bought the Grid about five years ago so I could eliminate other electrical components in the race car. The MSD Grid literally has everything built into it like a rev limiter (for each gear),ignition curve programming (for every gear change), engine starting retard, two step launch control, Data Acquisition (although rudimentary), internet upgradeable, controlling your air or electric shifter, and a v-net connector to connect and stream data to a racepack data acquisition system. These are just the operations of the Grid that I use! There are many more things that the grid can do but I don’t use them. You can buy a remote launch control to set launch RPM (which I currently use although you don’t need to) along with other modules for boost retard and traction control. To sum up, Grid makes all the other MSD ignitions seem primitive by comparison. So if you are fairly computer literate or know someone who is the Grid is for you.
If it ain't broke fix it anyway!
[Re: rebel]
#2494810
05/11/18 04:08 PM
05/11/18 04:08 PM
Posts: 2,926 A shed in England
Tig
A shed in England
As above. Even upgrading the firmware is a doddle. Will be fitting the ARC module to ours soon
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: rebel]
#2495531
05/13/18 02:26 PM
05/13/18 02:26 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Have one and been playing with it. Pretty simple and real good. 7-years & 100+ pages of questions/answers from some talented people. GRID INFO
"Any fool can know. The point is to understand"
- A. Einstein
