Page 1 of 3 1 2 3
SB 727 locked up #2491290
05/03/18 03:38 AM
05/03/18 03:38 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
Had the Duster at the track and second pass after the burnout car slowed at the hit and rear end hopped, drive shaft will not turn in any gear.
verified its not the rear end, fluid is clear and good, no issues with linkage checked convertor bolts. Thoughts?
this is on a 12.80 340 car any help would be great
I am going to talk to the guy who just rebuilt it in the AM but just searching for clues
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: SB 727 locked up [Re: Stroker Scamp] #2491408
05/03/18 12:20 PM
05/03/18 12:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Output shaft seized in the rear support. First thing popped into my mind. I don't know how bad a roller clutch or gear set would have to come apart to lock the whole thing up.
Re: SB 727 locked up [Re: CMcAllister] #2491736
05/03/18 10:51 PM
05/03/18 10:51 PM
pacific northwest
pacific northwest
should also note that its got new sprag and billet front drum going to take it out this weekend
Re: SB 727 locked up [Re: Stroker Scamp] #2491746
05/03/18 11:11 PM
05/03/18 11:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Guess I’d be dropping the pan to see if it hatched a porcupine egg. If you’ve seen a major trans failure and the ensuing mayhem stuck to the magnet, you’ll know what I’m talking about.
Re: SB 727 locked up [Re: J_BODY] #2491758
05/03/18 11:34 PM
05/03/18 11:34 PM
pacific northwest
pacific northwest
Yup, the pan will come off first. Question. is there anything that can come out of place and make this happen? No trans guy I am
Re: SB 727 locked up [Re: Stroker Scamp] #2491859
05/04/18 10:45 AM
05/04/18 10:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
CM’s scenario is a possibility..... I can’t think of anything off hand that isn’t the result of a major part failure. We’ll be waiting to see what is discovered.
Re: SB 727 locked up [Re: Stroker Scamp] #2491864
05/04/18 10:57 AM
05/04/18 10:57 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Sounds to me like you may have been unlucky and lucky at the same time.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: SB 727 locked up [Re: Stroker Scamp] #2492019
05/04/18 03:16 PM
05/04/18 03:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If the fluid's clean, it's not a friction element(s) welded itself together. Parking pawl is in the tail housing but never heard of one of them doing this. Anything failed to cause that will be in the back half/geartrain I would guess. If you start the engine and drop it in gear, does it act like it's in gear or does it free-rev?
Re: SB 727 locked up [Re: CMcAllister] #2492053
05/04/18 04:16 PM
05/04/18 04:16 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
Cocked servo piston holding it in two gears?
Re: SB 727 locked up [Re: CMcAllister] #2492086
05/04/18 05:01 PM
05/04/18 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Every seized output shaft/support I've seen had cherry red clean fluid.
Re: SB 727 locked up [Re: Stroker Scamp] #2492335
05/05/18 09:49 AM
05/05/18 09:49 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Not a 727, but I broke part of the converter snout off of a 904 way back. Happened at highway speed and locked up the driveshaft. Good times right there! I can't remember what the rebuiler said but I'm guessing it shot enough large bits through system when the broken piece made its way into the front pump to wedge fragments in throught the system. I do remember the fluid still seemed fine because it had no time to scorch and the bits were big enough to sink in the pan and not show up on the dipstick.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: SB 727 locked up [Re: Stroker Scamp] #2492908
05/06/18 08:39 PM
05/06/18 08:39 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Maybe the parking pawl return spring broke?
More likely a broken rear sprag.
Re: SB 727 locked up [Re: J_BODY] #2493477
05/08/18 02:27 AM
05/08/18 02:27 AM
pacific northwest
pacific northwest
No "egg" pretty clear fluid, but not as clean as I would suspect
some fuzz on the magnet but not much
Re: SB 727 locked up [Re: CMcAllister] #2493478
05/08/18 02:28 AM
05/08/18 02:28 AM
pacific northwest
pacific northwest
no change in rpm from gear to gear
Re: SB 727 locked up [Re: Stroker Scamp] #2494502
05/10/18 08:21 PM
05/10/18 08:21 PM
pacific northwest
pacific northwest
Dropped the pan and fluid does have quite a bit of fine shiny stuff.
Took it in and wound up the sprag failed and chewed into the case,
clutches in the front drum some were coming apart.
So at this point not exactly sure what caused the failure but any ideas on that would help
Re: SB 727 locked up [Re: Stroker Scamp] #2494671
05/11/18 09:39 AM
05/11/18 09:39 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Question when you did your burnouts where you starting out in first gear.
JAKES AUTOMOTIVE
Re: SB 727 locked up [Re: Stroker Scamp] #2494809
05/11/18 04:08 PM
05/11/18 04:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what kind of new sprag ?
Re: SB 727 locked up [Re: JAKE68] #2494831
05/11/18 05:51 PM
05/11/18 05:51 PM
pacific northwest
pacific northwest
Drive with a stock valve body, that may be the problem
Re: SB 727 locked up [Re: JohnRR] #2494832
05/11/18 05:52 PM
05/11/18 05:52 PM
pacific northwest
pacific northwest
A & A super sprag
Re: SB 727 locked up [Re: Stroker Scamp] #2494906
05/11/18 09:33 PM
05/11/18 09:33 PM
A727Tflite Online content
A727Tflite  Online Content
I'd sure like to see a picture of this ORC failure.
Got one?
Page 1 of 3 1 2 3
