oil pressure switch removal #2493367
05/07/18 09:05 PM
05/07/18 09:05 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Done it before...67 440 block but the others had a nut to get to under the switch cannister. The one I need to remove looks like a socket would go over it but 1 1/16 is too big and 1.0 inch is not working. Is it a goofy metric ? any help is appreciated. Thanks in advance...thanks MOPARTS
Re: oil pressure switch removal [Re: terzmo] #2493403
05/07/18 11:04 PM
05/07/18 11:04 PM
You might grab your vice grips with the angled serrations & a rag & grip it just tight enough so you can break it loose & leave minimal damage (if that is critical). I believe there is a special socket for this.
Re: oil pressure switch removal [Re: terzmo] #2493405
05/07/18 11:09 PM
05/07/18 11:09 PM
PA
70Duster Offline
70Duster  Offline
PA
Yes, there is a special socket made for oil pressure sending units.
I've also used a water pump pliers successfully in a pinch.
Re: oil pressure switch removal [Re: terzmo] #2493406
05/07/18 11:11 PM
05/07/18 11:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
They make special socket for oil sending unit removal, but a deep well 1 1/16 6 point socket will do the job. 12 point sockets won't work, the sending unit has no corners the 12 point has to grab. The 6 point grabs on the flats. Gene
Re: oil pressure switch removal [Re: poorboy] #2493455
05/08/18 12:42 AM
05/08/18 12:42 AM
Ding ding ding I (do) believe we have a winna!
Re: oil pressure switch removal [Re: terzmo] #2493493
05/08/18 04:11 AM
05/08/18 04:11 AM
Cab_Burge Online work
Cab_Burge  Online Work
try using a 1 1/16 impact socket on it twocents scope
Re: oil pressure switch removal [Re: terzmo] #2494194
05/10/18 12:26 AM
05/10/18 12:26 AM
Maryland
MoparMike1974 Offline
Maryland
I bought the special socket for this about 25 years ago. It was less than 10 bucks back then, probably pretty cheap still.
Re: oil pressure switch removal [Re: terzmo] #2494607
05/11/18 01:08 AM
05/11/18 01:08 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I never bought the special socket, I've always used my 6 point deep well 1 1/16" socket from my 1/2" socket set. Gene
Re: oil pressure switch removal [Re: poorboy] #2494613
05/11/18 01:16 AM
05/11/18 01:16 AM
^^^ Gene I am gonna use that on my next encounter, thank you!
Re: oil pressure switch removal [Re: terzmo] #2494885
05/11/18 08:09 PM
05/11/18 08:09 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thanks to all...I friend lent me the socket and all went well. Thanks again...Thanks MOPARTS
Re: oil pressure switch removal [Re: terzmo] #2494887
05/11/18 08:18 PM
05/11/18 08:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I bought a that socket many years ago and only used it one time. Never needed it again that I remember.
