Re: oil pressure switch removal
[Re: terzmo]
#2493403
05/07/18 11:04 PM
05/07/18 11:04 PM
RapidRobert
You might grab your vice grips with the angled serrations & a rag & grip it just tight enough so you can break it loose & leave minimal damage (if that is critical). I believe there is a special socket for this.
[Re: poorboy]
#2493455
05/08/18 12:42 AM
05/08/18 12:42 AM
RapidRobert
They make special socket for oil sending unit removal, but a deep well 1 1/16 6 point socket will do the job. 12 point sockets won't work, the sending unit has no corners the 12 point has to grab. The 6 point grabs on the flats. Gene Ding ding ding I (do) believe we have a winna!
[Re: poorboy]
#2494613
05/11/18 01:16 AM
05/11/18 01:16 AM
RapidRobert
^^^ Gene I am gonna use that on my next encounter, thank you!
