Re: 71 cuda rear shock issues...need advice
[Re: bugsydog]
#2492880
05/06/18 07:32 PM
05/06/18 07:32 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
Unless the other shocks were air shocks or spring booster shocks, the height should not be affected. Oil filled shocks (stock) will settle to the normal sprung height. They don't hold-up the suspension.
[Re: bugsydog]
#2492910
05/06/18 08:40 PM
05/06/18 08:40 PM
RapidRobert
I don't have an answer but I would put the old shocks back on for a quick test just to see if they raise it back up. & maybe compress both shocks to the height you have between shock studs with no shocks on there & see if they are smooth or tight/binding at that dimention.
[Re: bugsydog]
#2492930
05/06/18 09:57 PM
05/06/18 09:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
i replaced my rear shocks on my 71 cuda and when i put the car back on the ground the rear is lower than it was before, tire will rub the quarter panel. i don't know what brand the other shocks were, and the new shocks are oem. What would have caused this problem? Take a look at the rear spring shackles, which way are the spring ends of the shackles angled/pointed, towards the front or rear of the car?
