71 cuda rear shock issues...need advice #2492877
05/06/18 07:25 PM
05/06/18 07:25 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
i replaced my rear shocks on my 71 cuda and when i put the car back on the ground the rear is lower than it was before, tire will rub the quarter panel. i don't know what brand the other shocks were, and the new shocks are oem. What would have caused this problem?
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492880
05/06/18 07:32 PM
05/06/18 07:32 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Unless the other shocks were air shocks or spring booster shocks, the height should not be affected. Oil filled shocks (stock) will settle to the normal sprung height. They don't hold-up the suspension.
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492883
05/06/18 07:44 PM
05/06/18 07:44 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
Hi Sunroofcuda,
the others were not air shocks, the car was lowered 2", 10 years ago when i put on new springs on the car. at this point the car is undriveable due to rear tire rub.
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492910
05/06/18 08:40 PM
05/06/18 08:40 PM
I don't have an answer but I would put the old shocks back on for a quick test just to see if they raise it back up. & maybe compress both shocks to the height you have between shock studs with no shocks on there & see if they are smooth or tight/binding at that dimention.
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492930
05/06/18 09:57 PM
05/06/18 09:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Take a look at the rear spring shackles, which way are the spring ends of the shackles angled/pointed, towards the front or rear of the car?
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492931
05/06/18 09:58 PM
05/06/18 09:58 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Oem as in 40 year old shocks?..
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492940
05/06/18 10:14 PM
05/06/18 10:14 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
they are new shocks purchased from summit racing.
Re: 71 cuda rear shock issues...need advice [Re: bugsydog] #2492988
05/06/18 11:35 PM
05/06/18 11:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect the old shocks were stuck in a position, or the rear spring shackles were originally flipped the wrong direction therefore holding the back end up and are now correct position and are allowing the rear to settle down where is should have been.
The only other thing that comes to mind is that the rear springs are broken, and the old shocks were stiff enough to hide the problem. Gene
