Re: A body disc brake conversion issue [Re: RapidRobert] #2492488
05/05/18 05:10 PM
05/05/18 05:10 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I did pull the mc apart. Cleaned it out and reassembled it yesterday.That's why I eliminated that as a problem.
Re: A body disc brake conversion issue [Re: maximus] #2492825
05/06/18 03:55 PM
05/06/18 03:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By maximus
I now took apart master cylinder. Question should all 4 seals face forward? The second one on the front piston is facing rearward, that is for the rear of the car.
In normal operation the rear piston pushes the front piston hydraulically, that's why the rear seal on the front piston faces aft to face the pressure from the rear piston.
Only during a system failure does the rear piston physically contact the front piston.
Re: A body disc brake conversion issue [Re: John_Kunkel] #2492837
05/06/18 04:45 PM
05/06/18 04:45 PM
John you're the man!
