'70 master cyl spacer? #1245839
06/05/12 03:15 PM
06/05/12 03:15 PM
Kelowna, B.C. Canada
DPelletier Offline OP
Does anyone know if there was a plastic spacer used between the master cylinder and booster on any 1970 disc brake applications? I've had a couple people mention that some cars had more than just the thin gasket and used a white plastic spacer approx. 1/4" thick?
The part number I've been given is # 2401862. I went through quite an ordeal a while back trying to get my MC/booster/linkage/pedal all to work despite everything being apparently correct...a missing spacer would seem to explain things.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: '70 master cyl spacer? [Re: DPelletier] #1245840
06/05/12 04:05 PM
06/05/12 04:05 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
My '70 RR has factory disc brakes and it does not have that spacer. System works good and I never had any issue with it.
Re: '70 master cyl spacer? [Re: 70mopes] #1245841
06/05/12 04:40 PM
06/05/12 04:40 PM
Thanks. I'm thinking B bodies didn't have them, but was wondering if maybe C bodies or something did...and maybe I have a C body Booster.
Not sure what the problem is, but now my buddy has the same issue and we thought....
Re: '70 master cyl spacer? [Re: DPelletier] #1245842
06/05/12 06:00 PM
06/05/12 06:00 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
I just replaced mine last weekend and there was only the thin ,foam gasket.Someone was talking about adjustmant in the rod to make things work differently.I have replaced the booster(4 years ago) and just did the master cylinder with no problems.Good luck.
Re: '70 master cyl spacer? [Re: 70RR383] #1245843
06/05/12 07:37 PM
06/05/12 07:37 PM
yes, there is a threaded "knob" on the end of the rod that pushes into the MC but there isn't enough adjustment to fix my problem. I ended up putting a spacer between the firewall and the booster to stop the plunger from being depressed before the pedal is engaged. It works; I just don't like it.
Re: '70 master cyl spacer? [Re: DPelletier] #1245844
06/06/12 07:27 PM
06/06/12 07:27 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Might you be thinking of the white plastic spacer used on power DRUM brake cars??? Not used on power disc cars...
Tom
68 Charger
70 Cuda
Re: '70 master cyl spacer? [Re: FC7cuda] #1245845
06/07/12 12:26 PM
06/07/12 12:26 PM
Tom
Yes, I think you're right; I took a look at a drum brake booster last night with the spacer....I've never seen one on a disk brake booster, but thought maybe C bodies or something might have used them.....I've never paid much attention to C body details.
Re: '70 master cyl spacer? [Re: DPelletier] #1245846
06/07/12 01:23 PM
06/07/12 01:23 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
A bit off the beaten path....
I have a '68 charger with power drum brakes that was missing all its components when I found it. I got all the original parts but I did not use the spacer being discussed. I have had some strange issues with my brakes since building it and have got them to work pretty good but not perfect.
Question what would be side affect(s) of a power drum brake car that did not have said spacer installed?
I have never seen this part before so if I were to try and find one or fabricate one, how should I go about it?
Thanks!
Re: '70 master cyl spacer? [Re: 70mopes] #1245847
06/07/12 02:00 PM
06/07/12 02:00 PM
Thanks!
PM member Chargervic; he just took off the drum brake booster with the spacer off his '68 charger as he's doing a disc swap. Without the spacer, I'd imagine you may not have enough adjustment in the rod pushing the master cyl piston in which could cause travel issues, difficuly bleeding, etc.
Re: '70 master cyl spacer? [Re: DPelletier] #1245848
06/07/12 02:46 PM
06/07/12 02:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you could also put a piece of paper over the master cylinder rear end, trace the outline on to the paper then use you 'template' to make one?
Re: '70 master cyl spacer? [Re: mikemee1331] #2491602
05/03/18 05:49 PM
05/03/18 05:49 PM
New York
rarefish Offline
rarefish  Offline
New York
Here is a pic of the one on my power disc brake 1969 A-body.
Re: '70 master cyl spacer? [Re: DPelletier] #2491654
05/03/18 07:44 PM
05/03/18 07:44 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Both my 70 V code 70 Bees are disk brake with no spacer
Re: '70 master cyl spacer? [Re: DPelletier] #2492055
05/04/18 04:19 PM
05/04/18 04:19 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
My 70 V code Bee is an original track pack drum brake car. I have the original drum brake booster in one of my totes. I will check it out later tonight. How do you tell the difference between a drum/disc brake booster?
Re: '70 master cyl spacer? [Re: Cuda340] #2492093
05/04/18 05:09 PM
05/04/18 05:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I believe the boosters were the same. The MCs were different. 70 B Body disk brake MC the lines exit toward the exhaust manifold.
Re: '70 master cyl spacer? [Re: DPelletier] #2492714
05/06/18 10:49 AM
05/06/18 10:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted By DPelletier
Thanks. I'm thinking B bodies didn't have them, but was wondering if maybe C bodies or something did...and maybe I have a C body Booster. <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" />
Not sure what the problem is, but now my buddy has the same issue and we thought.... <img src="/ubbthreads/images/graemlins/1343795-scratchchin.gif" alt="" />
No gasket or spacer on any B body disc brake application 1967 thru 1970
Re: '70 master cyl spacer? [Re: Morty426] #2492958
05/06/18 10:53 PM
05/06/18 10:53 PM
Chicago
PurpleBeeper Offline
Chicago
My OEM power front disk brake 70 Roadrunner has the brake lines exiting the master cylinder towards the firewall. I've always been confused about this & have picked up several master cylinders over the years that were "supposed" to be correct, but were not. I've owned 3 different types.
a. shorter/fatter one with fender exit lines (on my car now)
b. shorter/fatter onw with engine exit lines
c. taller/thinner one (smaller cover too) - can't remember which side the lines are...maybe Hemi or C-body?
And if anyone is stuck... I believe I have one of those plastic white spacers.
Lastly, I believe the power drum boosters are flatter & larger diameter. I ran one for many years when you couldn't buy power disk boosters aftermarket.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
