'70 master cyl spacer?
#1245839
06/05/12 03:15 PM
06/05/12 03:15 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Does anyone know if there was a plastic spacer used between the master cylinder and booster on any 1970 disc brake applications? I've had a couple people mention that some cars had more than just the thin gasket and used a white plastic spacer approx. 1/4" thick? The part number I've been given is # 2401862. I went through quite an ordeal a while back trying to get my MC/booster/linkage/pedal all to work despite everything being apparently correct...a missing spacer would seem to explain things. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: '70 master cyl spacer?
[Re: 70mopes]
#1245841
06/05/12 04:40 PM
06/05/12 04:40 PM
DPelletier
Thanks. I'm thinking B bodies didn't have them, but was wondering if maybe C bodies or something did...and maybe I have a C body Booster. Not sure what the problem is, but now my buddy has the same issue and we thought.... Dave
1974 'Cuda
[Re: 70RR383]
#1245843
06/05/12 07:37 PM
06/05/12 07:37 PM
DPelletier
yes, there is a threaded "knob" on the end of the rod that pushes into the MC but there isn't enough adjustment to fix my problem. I ended up putting a spacer between the firewall and the booster to stop the plunger from being depressed before the pedal is engaged. It works; I just don't like it. Dave
1974 'Cuda
[Re: DPelletier]
#1245844
06/06/12 07:27 PM
06/06/12 07:27 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Might you be thinking of the white plastic spacer used on power DRUM brake cars??? Not used on power disc cars... Tom
68 Charger 70 Cuda
[Re: 70mopes]
#1245847
06/07/12 02:00 PM
06/07/12 02:00 PM
DPelletier
A bit off the beaten path....
I have a '68 charger with power drum brakes that was missing all its components when I found it. I got all the original parts but I did not use the spacer being discussed. I have had some strange issues with my brakes since building it and have got them to work pretty good but not perfect.
Question what would be side affect(s) of a power drum brake car that did not have said spacer installed?
I have never seen this part before so if I were to try and find one or fabricate one, how should I go about it?
Thanks!
PM member Chargervic; he just took off the drum brake booster with the spacer off his '68 charger as he's doing a disc swap. Without the spacer, I'd imagine you may not have enough adjustment in the rod pushing the master cyl piston in which could cause travel issues, difficuly bleeding, etc.
1974 'Cuda
[Re: Cuda340]
#2492093
05/04/18 05:09 PM
05/04/18 05:09 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
My 70 V code Bee is an original track pack drum brake car. I have the original drum brake booster in one of my totes. I will check it out later tonight. How do you tell the difference between a drum/disc brake booster? I believe the boosters were the same. The MCs were different. 70 B Body disk brake MC the lines exit toward the exhaust manifold.
[Re: DPelletier]
#2492714
05/06/18 10:49 AM
05/06/18 10:49 AM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
Thanks. I'm thinking B bodies didn't have them, but was wondering if maybe C bodies or something did...and maybe I have a C body Booster. <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" />
Not sure what the problem is, but now my buddy has the same issue and we thought.... <img src="/ubbthreads/images/graemlins/1343795-scratchchin.gif" alt="" />
Dave No gasket or spacer on any B body disc brake application 1967 thru 1970
[Re: Morty426]
#2492958
05/06/18 10:53 PM
05/06/18 10:53 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
My 70 V code Bee is an original track pack drum brake car. I have the original drum brake booster in one of my totes. I will check it out later tonight. How do you tell the difference between a drum/disc brake booster? I believe the boosters were the same. The MCs were different. 70 B Body disk brake MC the lines exit toward the exhaust manifold. My OEM power front disk brake 70 Roadrunner has the brake lines exiting the master cylinder towards the firewall. I've always been confused about this & have picked up several master cylinders over the years that were "supposed" to be correct, but were not. I've owned 3 different types. a. shorter/fatter one with fender exit lines (on my car now) b. shorter/fatter onw with engine exit lines c. taller/thinner one (smaller cover too) - can't remember which side the lines are...maybe Hemi or C-body? And if anyone is stuck... I believe I have one of those plastic white spacers. Lastly, I believe the power drum boosters are flatter & larger diameter. I ran one for many years when you couldn't buy power disk boosters aftermarket.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
