Re: Attn: Jim at Detroit Muscle Technologies
[Re: mopars4ever]
#2524425
07/20/18 10:34 AM
07/20/18 10:34 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Yes, mine leaks also.
I Park the truck up hill just to keep the headliner from staining
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2524528
07/20/18 01:52 PM
07/20/18 01:52 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
I Park the truck up hill just to keep the headliner from staining Yikes.
[Re: mopars4ever]
#2524623
07/20/18 04:37 PM
07/20/18 04:37 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
My 2000 leaked. They told me to silicone it - I did and that solved the problem.
[Re: burdar]
#2524624
07/20/18 04:38 PM
07/20/18 04:38 PM
Posts: 601 Mass
charge70
Mass
I believe the issue is with the 09-18 models. I haven't had a problem yet with my 14. The lights have a screw at each end but the center does not. The housing has some flex to it so it doesn't push up tight to the body. At least that's what it looked like to me when I took mine out to change the bulb. My 05 Daytona leaks water thru the 3rd brake lite,so the problem is earlier than 09.After Googling this it seems that this is a real common problem with these trucks.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 71TA]
#2524629
07/20/18 04:52 PM
07/20/18 04:52 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
How did I miss this and what years are we talking about? I don't know about the newer ones, but it started in 1994. I've always just assumed they'd solved it at some point, apparently not. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: mopars4ever]
#2524632
07/20/18 05:00 PM
07/20/18 05:00 PM
Posts: 8,674 Buford, GA
I_bleed_MOPAR
Buford, GA
'02-up 1500s and '03-up 2500s leak there. My '06 did. Made a new gasket like others. I also found something about sealing the rear window... Don't know about earlier Rams. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: mopars4ever]
#2524639
07/20/18 05:11 PM
07/20/18 05:11 PM
Posts: 146 Missouri
randavis
Missouri
My 13 leaks at the sliding rear window. I haven't figured out how to stop that yet. The water runs down to the well under the rear seat on the passenger side. I have a sponge in there to absorb it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: mopars4ever]
#2524691
07/20/18 07:33 PM
07/20/18 07:33 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Literally 1,000 threads on any of the Ram Forums
I caught my 2011 early - Filled up the storage area with water behind the drivers seat , under the rear seat during a down poor literally brand new
I gutted the interior and dried everything out - Lucky my headliner was untouched
I already knew what the dealer fix under warranty was
So Metro self stick weatherstripping at Autozone has worked awesome ever since , just clean and scrape off the cheap gasket first off the third brake light
I cant believe dealers where actually using silicone adhesive or just replacing the third brake light with the crap gasket over again
On the sliding rear window all I had to do was blow out the three water channels under the bottom seal with compressed air
Two of them where filled with black adhesive from the factory so the water could never escape
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 71TA]
#2524767
07/20/18 09:50 PM
07/20/18 09:50 PM
Posts: 3,080 N.W. Florida
Fat_Mike
N.W. Florida
How did I miss this and what years are we talking about? To be honest I think it's Generations 2, 3 and 4 with Gen 3 and 4 being the worst.
[Re: mopars4ever]
#2525266
07/22/18 11:36 AM
07/22/18 11:36 AM
Posts: 1,487 STL
cdstl
STL
On the Second Gens, 1994-2001. I take a strip of foam weather strip and run it continuously from the bottom of one side up and over the top to the bottom of the other side. Then I run a strip along the bottom.
Seems to work.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: mopars4ever]
#2525372
07/22/18 03:12 PM
07/22/18 03:12 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Jim, if you make some good ones that do the trick, I'll take one.
-Eric
[Re: mopars4ever]
#2525666
07/23/18 12:40 AM
07/23/18 12:40 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I'm in. 2014 Ram Express. TIA
Common sense is a flower that does not grow in everybody's garden
[Re: mopars4ever]
#2525743
07/23/18 09:05 AM
07/23/18 09:05 AM
Posts: 601 Mass
charge70
Mass
I'm in also.2005 Dodge Daytona.
