Re: A body disc brake conversion issue
[Re: maximus]
#2491893
05/04/18 11:51 AM
05/04/18 11:51 AM
Posts: 8,672 Buford, GA
I_bleed_MOPAR
Buford, GA
Having to pump the pedal sounds like air in the lines. Did you bench-bleed the master before installation? Are the bleeder screws at top of calipers?
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2491918
05/04/18 12:24 PM
05/04/18 12:24 PM
RapidRobert
Did you bench-bleed the master before installation? X2
[Re: maximus]
#2491946
05/04/18 01:17 PM
05/04/18 01:17 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
What brake fluid did you use?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: maximus]
#2491957
05/04/18 01:33 PM
05/04/18 01:33 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Are the bleeders up?Thats sounds like the probem.Dont ask how I know.Its an easy mistake to mount the calipars with the bleeders pointing down.Rocky
Chrysler Firepower
[Re: maximus]
#2492097
05/04/18 05:14 PM
05/04/18 05:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
No, one block only. Inline Tube told me only one used on 69 to 74 A bodies. I found an old manual and it looks like the seals (piston cups) are all in the right direction.I put the master cylinder back in the car, bleed the cylinder, then hook it back together. Bleed the system again, tighten the rear brake to the point of dragging. First time I hit the pedal after all this and it goes to the floor, hit it again and it tightens up about 2/3 down. Pump the brakes a few more times and it stays about the same. Let it set for one minute try again and it goes to the floor again. What the heck. The pedal issue sounds like air still trapped in the system, are you using an "Inline" brand PV, they are known to be junk, how was fluid flow out the rears when bleeding? I've had situations where there was trapped air in the front calipers, and no amount of pumping/bleeding was going to resolve the issue, so I would remove each caliper, starting at the passenger side, compress the piston fully with a C clamp, keeping the piston compressed with the clamp I would have an assistant gently pump the pedal/hold pressure then open the bleeder, rinse and repeat a few times, then remove the C clamp and install the caliper/pads and pump that caliper piston into position, then repeat for the drivers side, worth a shot If you have a faulty PV valve and/or its closed not allowing the rears to bleed properly that's another issue
[Re: maximus]
#2492199
05/04/18 10:15 PM
05/04/18 10:15 PM
Posts: 5,886 ohio
ruderunner
ohio
Sounds like a bad master to me. Plug the ports on the master, pedal should be rock hard.
Angry white pureblood male
[Re: ruderunner]
#2492208
05/04/18 10:41 PM
05/04/18 10:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Sounds like a bad master to me. Plug the ports on the master, pedal should be rock hard. It could be?, fluid blowing past the piston/seals, and it could be trapped air? often difficult issues, esp trying to troubleshoot via the net...
[Re: DAYCLONA]
#2492229
05/04/18 11:55 PM
05/04/18 11:55 PM
RapidRobert
I would assume that all of the seals should be faceing forward & if one ain't then that is a first for me but with assembly line rebuilds it is certainly possible either from an assembler spacing off or pi$$ed off about something. I would definitely get that resolved however which way you do it then with it bled out & capped, the pedal should be (1) rock hard with (2) virtually no travel with (3) light pedal force & by (4) stomping on it. with the MC resolved then you can uncap/hookup the fronts & as said sometimes calipers can be a bear to bleed. sometimes having a helper vigoriously pumping the pedal then you with perfect timing opening the bleeder on his 4th downstroke will be enough to agitate the fluid & scoot the bubbles out of there & sometimes a caliper needs to be removed & the piston travel blocked & it bled while you hold it in a better position but I think the MC seal is the problem (for sure holler what it ends up being).
[Re: maximus]
#2492396
05/05/18 12:44 PM
05/05/18 12:44 PM
RapidRobert
I'm sure glad we didn't talk you into pulling the guts out of the MC!
[Re: maximus]
#2492825
05/06/18 03:55 PM
05/06/18 03:55 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I now took apart master cylinder. Question should all 4 seals face forward? The second one on the front piston is facing rearward, that is for the rear of the car. In normal operation the rear piston pushes the front piston hydraulically, that's why the rear seal on the front piston faces aft to face the pressure from the rear piston. Only during a system failure does the rear piston physically contact the front piston.
