E body remote mirror cable routing #2490931
05/02/18 03:38 PM
05/02/18 03:38 PM
Los Angeles, CA
71_dramaqueen Offline OP
Los Angeles, CA
When I purchased my challenger the remote driver side mirror had the cable going through one of the holes in the glass. It pulled through the hole and made a nice scraping sound every time the window when up and down.
What is the correct routing for the cable and if it is through the window, is there supposed to be a grommet to stop the cable from rubbing?
thanks
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: E body remote mirror cable routing [Re: 71_dramaqueen] #2490934
05/02/18 03:47 PM
05/02/18 03:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It does not go through the window.
Is the car a 71? 70 and 71 are slightly different.
Re: E body remote mirror cable routing [Re: 71_dramaqueen] #2490992
05/02/18 05:11 PM
05/02/18 05:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks
Does not go thru glass in any way, it's routed around the front of the glass....
Re: E body remote mirror cable routing [Re: Morty426] #2491699
05/03/18 09:39 PM
05/03/18 09:39 PM
Los Angeles, CA
Los Angeles, CA
71' - What's the difference? only one of the doors is original.
Grrrr why mother Mopar did you change so many little things from one model year to the next....
Thanks for the diagram.
Re: E body remote mirror cable routing [Re: 71_dramaqueen] #2491737
05/03/18 10:56 PM
05/03/18 10:56 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Everything changed in 71 even though it does not look it. 71 has a plastic loop clip on the cables that pushes into a brace inside the door. Holds the cables away from the front of the glass.
