E body remote mirror cable routing
#2490931
05/02/18 03:38 PM
05/02/18 03:38 PM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
When I purchased my challenger the remote driver side mirror had the cable going through one of the holes in the glass. It pulled through the hole and made a nice scraping sound every time the window when up and down.
What is the correct routing for the cable and if it is through the window, is there supposed to be a grommet to stop the cable from rubbing?
thanks
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: E body remote mirror cable routing
[Re: 71_dramaqueen]
#2490992
05/02/18 05:11 PM
05/02/18 05:11 PM
Posts: 18,157 Mass
DAYCLONA
Mass
thanks Does not go thru glass in any way, it's routed around the front of the glass....
[Re: Morty426]
#2491699
05/03/18 09:39 PM
05/03/18 09:39 PM
71_dramaqueen
Los Angeles, CA
71' - What's the difference? only one of the doors is original.
Grrrr why mother Mopar did you change so many little things from one model year to the next....
Thanks for the diagram.
[Re: 71_dramaqueen]
#2491737
05/03/18 10:56 PM
05/03/18 10:56 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Thanks for the diagram. Everything changed in 71 even though it does not look it. 71 has a plastic loop clip on the cables that pushes into a brace inside the door. Holds the cables away from the front of the glass.
