Grease exiting green bearings #2490949
05/02/18 04:17 PM
05/02/18 04:17 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
End of the season last year the rear end (8 3/4 3.91 cone suregrip) started making some noise, a constant growl. the noise does not change turning right or left which makes me think it's in the center section but when I pulled the wheels & drums this is what i saw on the left axle.
what do you guys think? time to change the wheel bearing? since they are sealed I would think this is not a good thing, or is it just the bearing in the center section? any Ideas on further diagnosis?
Oh yea 489 case.
now that it's finally warming up I need to get the car ready for some action.
thanks,
Gary
Re: Grease exiting green bearings [Re: Mr340] #2490975
05/02/18 04:44 PM
05/02/18 04:44 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You need to diag the rear anyway,they don't last forever.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Grease exiting green bearings [Re: hemi-itis] #2490979
05/02/18 04:51 PM
05/02/18 04:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Needs to be replaced.. how long has it been in
there
wave
Re: Grease exiting green bearings [Re: MR_P_BODY] #2491007
05/02/18 05:50 PM
05/02/18 05:50 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Checked my notes and the axles with the greens have been in since nov. of '13 so thats 4 seasons, and the gear and sure grip longer, probobly another 3 years. lotss long than I thought,seemed like just yesterday LOL. whistling
Re: Grease exiting green bearings [Re: Mr340] #2491457
05/03/18 01:33 PM
05/03/18 01:33 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Are you running inner axle seals? If no, that could be your problem. I have been told (take it with a grain of salt) but is has some validity. That the bearings aren't totally sealed. The oil will eventually seep in and wash the grease out. It is possible that this is happening. If you have the seals. Out goes my theory... lol
Re: Grease exiting green bearings [Re: Cuda340] #2491735
05/03/18 10:51 PM
05/03/18 10:51 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
I am runnning inner seals..but thanks for the thought.
Re: Grease exiting green bearings [Re: Mr340] #2491740
05/03/18 11:00 PM
05/03/18 11:00 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I find it hard to believe it cooked so much to expel that much grease.I would think there is bearing damage/heet.Pull the axle and check/spin the bearing
Re: Grease exiting green bearings [Re: Mr340] #2491755
05/03/18 11:31 PM
05/03/18 11:31 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I’m guessing the leaking bearing is bad and overheating blowing the Grease out
Pull that axle and feel the bearing is what I would do.
Re: Grease exiting green bearings [Re: NTOLERANCE] #2492110
05/04/18 05:42 PM
05/04/18 05:42 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
pulled both axles today and they both feel nice and smooth, no grease coming out the right hand axle bearing. I have my old axles with the tapered bearing, maybe I'll throw those in and take it for a ride just to see if the noise is still there.
I'm thinking it's the center section but the bearing leaking still will need to be replaced.
Re: Grease exiting green bearings [Re: Mr340] #2492192
05/04/18 09:48 PM
05/04/18 09:48 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Found the noise now I just need to figure out why the grease was leaking
Re: Grease exiting green bearings [Re: Mr340] #2492196
05/04/18 10:03 PM
05/04/18 10:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How easy was it to pull the leaking axle?Maybe the housing is bent on that side.or if you had new ends put on the housing it could be crooked by .010
Re: Grease exiting green bearings [Re: Mr340] #2492221
05/04/18 11:30 PM
05/04/18 11:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did the same thing to my 8.75. It got noisey and when i pulled the center I found the same thing as you, a few broken teeth. It had been together for a long long time as the car had progressively gotten faster. We were both lucky we caught it before it let all the way go!
68 Barracuda Formula S 340
Re: Grease exiting green bearings [Re: Mr340] #2492281
05/05/18 02:06 AM
05/05/18 02:06 AM
Is the pinion yoke loose? scope
The teeth marks on the posi are from the pinion gear backing up into it shock shruggy
One of the hazards of using the crush sleeves on a hard leaving car work
If you still have the crush sleeve in your rear end now is the time to swap it out for a pinion spacer and switch to pinion shims to set the bearing preload up properly up twocents
Re: Grease exiting green bearings [Re: Cab_Burge] #2492330
05/05/18 09:23 AM
05/05/18 09:23 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Good eye Cab, up I knew someone would spot that. Pinion is good, those marks are from a previous install. wrench
Re: Grease exiting green bearings [Re: Clanton] #2492334
05/05/18 09:35 AM
05/05/18 09:35 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Clanton, the housing and the ends are the ones the car was born with and the axles seemed to go together and come apart ok, no extra binding. shruggy
Re: Grease exiting green bearings [Re: Mr340] #2492353
05/05/18 10:49 AM
05/05/18 10:49 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Ok thanks,If it was bent the side load would cause more heat in the bearing.
Re: Grease exiting green bearings [Re: Bad340fish] #2492359
05/05/18 11:01 AM
05/05/18 11:01 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
only had one chipped tooth so yea good thing I caught it be fore any more damage happened. Last time at the track I felt what I thought was tire slip half way out, drive must of been the gear, just glad it didn't let go altogether. hammer
Re: Grease exiting green bearings [Re: Mr340] #2492465
05/05/18 04:04 PM
05/05/18 04:04 PM
Ohio
moparjoe360.4 Offline
Ohio
Good eye Gary, definitely better to catch that because of a noise instead of compete failure! I let dad burrow The center and axles out of the truck last year for Nostalgia Drags and it has now developed a noise, hopefully it’s something simple. Good luck getting yours fixed hope to see you at Milan next month.
Re: Grease exiting green bearings [Re: moparjoe360.4] #2492503
05/05/18 05:51 PM
05/05/18 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those bearings werent designed for street driving
but great for straight line stuff.. all the cornering
might have taken their toll on them
wave
Re: Grease exiting green bearings [Re: MR_P_BODY] #2492697
05/06/18 10:08 AM
05/06/18 10:08 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
I don't street drive it that much, a few local cruises and up to woodward once or twice that week, thought they would hold up to that. shruggy
Joe, hope yours is something minor. wrench
