Re: Grease exiting green bearings
[Re: Cuda340]
#2491735
05/03/18 10:51 PM
05/03/18 10:51 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Are you running inner axle seals? If no, that could be your problem. I have been told (take it with a grain of salt) but is has some validity. That the bearings aren't totally sealed. The oil will eventually seep in and wash the grease out. It is possible that this is happening. If you have the seals. Out goes my theory... lol I am runnning inner seals..but thanks for the thought.
[Re: Mr340]
#2491755
05/03/18 11:31 PM
05/03/18 11:31 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I’m guessing the leaking bearing is bad and overheating blowing the Grease out
Pull that axle and feel the bearing is what I would do.
[Re: NTOLERANCE]
#2492110
05/04/18 05:42 PM
05/04/18 05:42 PM
Mr340
Richmond Twp. Mi.
pulled both axles today and they both feel nice and smooth, no grease coming out the right hand axle bearing. I have my old axles with the tapered bearing, maybe I'll throw those in and take it for a ride just to see if the noise is still there. I'm thinking it's the center section but the bearing leaking still will need to be replaced.
[Re: Mr340]
#2492196
05/04/18 10:03 PM
05/04/18 10:03 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Found the noise now I just need to figure out why the grease was leaking How easy was it to pull the leaking axle?Maybe the housing is bent on that side.or if you had new ends put on the housing it could be crooked by .010
[Re: Mr340]
#2492221
05/04/18 11:30 PM
05/04/18 11:30 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I did the same thing to my 8.75. It got noisey and when i pulled the center I found the same thing as you, a few broken teeth. It had been together for a long long time as the car had progressively gotten faster. We were both lucky we caught it before it let all the way go!
68 Barracuda Formula S 340
[Re: Mr340]
#2492353
05/05/18 10:49 AM
05/05/18 10:49 AM
Clanton
northern,Ohio,USA
Clanton, the housing and the ends are the ones the car was born with and the axles seemed to go together and come apart ok, no extra binding. Ok thanks,If it was bent the side load would cause more heat in the bearing.
[Re: moparjoe360.4]
#2492503
05/05/18 05:51 PM
05/05/18 05:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Those bearings werent designed for street driving but great for straight line stuff.. all the cornering might have taken their toll on them
