Got my Charger running #2478462
04/06/18 07:37 PM
04/06/18 07:37 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Got my car running again after my SFT tool steel lifter fail, went back through the engine, did some more port work on my heads & the Indy intake, I went hydro roller & used the high rpm Morel lifters, you can set these .020 from the bottom out of the lifter plunger, the old SFT cam was 248@.050,.570 lift, ran 116 mph 3000DA,4100lbs, new hydro roller from Hughes is 255in,258ex @.050,,.608 .613 lift, also went from a 2800ish converter to a 4000 custom built lock up converter for my A518 trans from PATC , car feels MUCH better & faster, if the weather is good will go to the track next week,the 14th, will keep Y'all posted.
LINK TO VIDEO OF CAR RUNNING
Re: Got my Charger running [Re: CSK] #2478475
04/06/18 08:03 PM
04/06/18 08:03 PM
birdtracker Offline
birdtracker  Offline
Congrats on the accomplishment. Keep us updated on how it runs. Birdtracker
Re: Got my Charger running [Re: CSK] #2478645
04/07/18 01:38 AM
04/07/18 01:38 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Looking forward to it.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Got my Charger running [Re: CSK] #2482541
04/14/18 12:52 PM
04/14/18 12:52 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Well we got rained out, we will try for next weekend, will keep Y'all posted.
Re: Got my Charger running [Re: CSK] #2482579
04/14/18 01:50 PM
04/14/18 01:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Congrats on getting it back together
wave
Re: Got my Charger running [Re: CSK] #2489166
04/28/18 06:31 PM
04/28/18 06:31 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Still no tuning I cant deal with the heat , 2nd pass it spun,
Drove 80 miles round-trip,ac blowin cold, overdrive engaged,,11.33@121, full exhaust, just drop the air pressure down to 20 psi and make a pass. DA was 1750 ,4100 lb pig.
Re: Got my Charger running [Re: CSK] #2489167
04/28/18 06:36 PM
04/28/18 06:36 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Nice job man. Great car.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Got my Charger running [Re: Wookie316] #2489217
04/28/18 09:01 PM
04/28/18 09:01 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Nice improvement, good MPH.
Your changes worked well. Congratulations
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Got my Charger running [Re: CSK] #2489229
04/28/18 09:30 PM
04/28/18 09:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sweet!Nice street car.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Got my Charger running [Re: CSK] #2489259
04/28/18 10:36 PM
04/28/18 10:36 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Low 11's with the A/C on! LOL! That's great. Good work. Just saw your video. I'm sure there will be some grumbling about your hood choice, but I think between the hood and airdam, that is a killer looking front end shot. Good luck with your project.
[image][/image]
Re: Got my Charger running [Re: sgcuda] #2489307
04/29/18 12:41 AM
04/29/18 12:41 AM
where the link to the vid help whistling AKA I would like to look at it also thumbs
Re: Got my Charger running [Re: Cab_Burge] #2489315
04/29/18 12:58 AM
04/29/18 12:58 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
He is talking about the video at the beginning of this thread, video of the 1/4 mile pass is coming soon smile
Re: Got my Charger running [Re: CSK] #2489495
04/29/18 01:49 PM
04/29/18 01:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks and sounds great and really nice improvement w/the bigger is USUALLY better cam swap............... thumbs biggrin
Re: Got my Charger running [Re: CSK] #2489537
04/29/18 03:02 PM
04/29/18 03:02 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds good!
Re: Got my Charger running [Re: ProSport] #2489570
04/29/18 04:48 PM
04/29/18 04:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice going as you have that sweet Charger flying. Congrats. beer Ron
Re: Got my Charger running [Re: CSK] #2490222
05/01/18 12:50 AM
05/01/18 12:50 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Looks/sounds awesome, Charlie.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Got my Charger running [Re: CSK] #2491572
05/03/18 04:22 PM
05/03/18 04:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well done, nice mph you got there!
Rich H.
Esse Quam Videri
Re: Got my Charger running [Re: CSK] #2491595
05/03/18 05:36 PM
05/03/18 05:36 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
This is a video that goes with the time slip I posted, I was asleep at the tree left easy & short shifted, & thanks for the support from all Y'all on Moparts smile
CLICK HERE FOR VIDEO
Re: Got my Charger running [Re: CSK] #2491600
05/03/18 05:47 PM
05/03/18 05:47 PM
an8sec70cuda Offline
Sounds like you made some nice improvements! Nice car, love the AC and OD trans...and the hood too!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Got my Charger running [Re: CSK] #2491606
05/03/18 05:55 PM
05/03/18 05:55 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
2nd race, I went up against the converter & blew the tires off.
