Got my Charger running
#2478462
04/06/18 07:37 PM
04/06/18 07:37 PM
Posts: 2,858 Pattison Texas
CSK
Pattison Texas
Got my car running again after my SFT tool steel lifter fail, went back through the engine, did some more port work on my heads & the Indy intake, I went hydro roller & used the high rpm Morel lifters, you can set these .020 from the bottom out of the lifter plunger, the old SFT cam was 248@.050,.570 lift, ran 116 mph 3000DA,4100lbs, new hydro roller from Hughes is 255in,258ex @.050,,.608 .613 lift, also went from a 2800ish converter to a 4000 custom built lock up converter for my A518 trans from PATC , car feels MUCH better & faster, if the weather is good will go to the track next week,the 14th, will keep Y'all posted. LINK TO VIDEO OF CAR RUNNING
Re: Got my Charger running
[Re: CSK]
#2482541
04/14/18 12:52 PM
04/14/18 12:52 PM
CSK
Pattison Texas
Well we got rained out, we will try for next weekend, will keep Y'all posted.
[Re: CSK]
#2489166
04/28/18 06:31 PM
04/28/18 06:31 PM
CSK
Pattison Texas
Still no tuning I cant deal with the heat , 2nd pass it spun, Drove 80 miles round-trip,ac blowin cold, overdrive engaged,,11.33@121, full exhaust, just drop the air pressure down to 20 psi and make a pass. DA was 1750 ,4100 lb pig.
[Re: Wookie316]
#2489217
04/28/18 09:01 PM
04/28/18 09:01 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Nice improvement, good MPH. Your changes worked well. Congratulations
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: CSK]
#2489259
04/28/18 10:36 PM
04/28/18 10:36 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Low 11's with the A/C on! LOL! That's great. Good work. Just saw your video. I'm sure there will be some grumbling about your hood choice, but I think between the hood and airdam, that is a killer looking front end shot. Good luck with your project.
[image][/image]
[Re: sgcuda]
#2489307
04/29/18 12:41 AM
04/29/18 12:41 AM
Posts: 43,165 Bend,OR USA
Cab_Burge
Low 11's with the A/C on! LOL! That's great. Good work. Just saw your video. I'm sure there will be some grumbling about your hood choice, but I think between the hood and airdam, that is a killer looking front end shot. Good luck with your project. where the link to the vid AKA I would like to look at it also
[Re: Cab_Burge]
#2489315
04/29/18 12:58 AM
04/29/18 12:58 AM
CSK
Pattison Texas
Low 11's with the A/C on! LOL! That's great. Good work. Just saw your video. I'm sure there will be some grumbling about your hood choice, but I think between the hood and airdam, that is a killer looking front end shot. Good luck with your project. where the link to the vid AKA I would like to look at it also He is talking about the video at the beginning of this thread, video of the 1/4 mile pass is coming soon
[Re: CSK]
#2490222
05/01/18 12:50 AM
05/01/18 12:50 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Looks/sounds awesome, Charlie.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: CSK]
#2491572
05/03/18 04:22 PM
05/03/18 04:22 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Well done, nice mph you got there!
Rich H.
Esse Quam Videri
[Re: CSK]
#2491595
05/03/18 05:36 PM
05/03/18 05:36 PM
CSK
Pattison Texas
This is a video that goes with the time slip I posted, I was asleep at the tree left easy & short shifted, & thanks for the support from all Y'all on Moparts CLICK HERE FOR VIDEO
[Re: CSK]
#2491600
05/03/18 05:47 PM
05/03/18 05:47 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Sounds like you made some nice improvements! Nice car, love the AC and OD trans...and the hood too!
[Re: CSK]
#2491606
05/03/18 05:55 PM
05/03/18 05:55 PM
CSK
Pattison Texas
2nd race, I went up against the converter & blew the tires off. CLICK HERE FOR VIDEO
