Mystery hole in intake #2488063
04/26/18 01:32 AM
04/26/18 01:32 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Does anyone know what this hole is in the bottom of my Edelbrock DP4B intake manifold is? What does it do and should it be plugged? It doesn't appear to lead anywhere...
Re: Mystery hole in intake [Re: jeebis44] #2488068
04/26/18 01:39 AM
04/26/18 01:39 AM
I would make a air pressure test with a air hose nozzle and see if that hole goes into the heat cross over passage in the bottom of that manifold, if it blows out the sides have that hole welded shut, if not don't worry about it work twocents
Re: Mystery hole in intake [Re: jeebis44] #2488087
04/26/18 02:25 AM
04/26/18 02:25 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
The plot thickens... So there is a mystery tube involved here, which runs inside the exhaust crossover cavity and exits from the top of the manifold.
i
Re: Mystery hole in intake [Re: jeebis44] #2488092
04/26/18 02:36 AM
04/26/18 02:36 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Heat source for automatic choke. Surely some of you remember automatic chokes on cars.
Re: Mystery hole in intake [Re: John Brown] #2488143
04/26/18 10:07 AM
04/26/18 10:07 AM
scratchnfotraction Offline
DING DING DING
yep. unhooked many of those heat tubes from carbs
no need to weld it shut.
Re: Mystery hole in intake [Re: scratchnfotraction] #2488183
04/26/18 11:47 AM
04/26/18 11:47 AM
moparx Offline
moparx  Offline
DING DING DING
iagree but to be on the safe side, air check it like cab said. you never know the complete history of any "old" part. if it does leak into the crossover, you can also tap that hole[or both] to a "xxx" fine thread, then use a short "button head" screw to plug it instead of welding.
beer
Re: Mystery hole in intake [Re: jeebis44] #2488187
04/26/18 11:52 AM
04/26/18 11:52 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
What about the one on the bottom? Is it possibly an EGR port?
Joe
Re: Mystery hole in intake [Re: jlatessa] #2488196
04/26/18 12:06 PM
04/26/18 12:06 PM
Joe
NO, this is a hole on each side with a steel tube inside connecting the 2 openings.
egr gasses will heat the tube and the air inside of it to heat the choke thermo spring.
idea is.. as the air inside the tube heats is rises to top of tube to carb choke housing connection. cool air flowing under intake is sucked up into tube and heated.
good idea to air check for leaks though. I have saw them with holes the tube from rust.
Re: Mystery hole in intake [Re: jeebis44] #2488197
04/26/18 12:15 PM
04/26/18 12:15 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
How in the heck did the factory put a steel tube through those holes, they aren't even close to lining up??
Not something I've seen before...
Joe
Re: Mystery hole in intake [Re: jlatessa] #2488217
04/26/18 12:56 PM
04/26/18 12:56 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
my LD340 has one as well. The steel tube was probably set in place in the empty mold and the aluminum poured in later casting itself around the tubing.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Mystery hole in intake [Re: jeebis44] #2488368
04/26/18 05:38 PM
04/26/18 05:38 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Aha!! we have a winner!!
Joe
Re: Mystery hole in intake [Re: jeebis44] #2488636
04/27/18 11:39 AM
04/27/18 11:39 AM
correct, during the casting process, pre-bent tube and positioned in the sand mold then cast.
not too bad as I have never saw one with casting shift enough to leak.
I have had to do some good amount of porting to correct casting shift flaws on intakes.
maybe QC inspect and they catch it before hand and melt/re-cast it.
Re: Mystery hole in intake [Re: jeebis44] #2489444
04/29/18 11:54 AM
04/29/18 11:54 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
The bottom hole is the intake port for the heated choke which draws a slight vacuum to pull the heated air through.
Re: Mystery hole in intake [Re: jeebis44] #2490211
05/01/18 12:34 AM
05/01/18 12:34 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Mystery solved - thanks!
