White vinyl interior: best product, method for cleaning? #2487111
04/24/18 03:35 AM
04/24/18 03:35 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What's the best, safest product for cleaning and restoring a white vinyl interior, seats, door and side panels back to as white color as possible?
It doesn't have any tears, rips or holes just not white like it used to be and I'd like to save it if possible. Thought about the whitewall tire bleach or marine mold/mildew products or vinyl and leather cleaner but if there is something that you might have had the best success with or the method using any product I'd really appreciate some help before going down the wrong path. Thanks in advance as always.
Mike
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2487181
04/24/18 11:21 AM
04/24/18 11:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you want to really strip the crap/dirt/aged look from white interior/exterior vinyl, I use 3M general purpose adhesive remover
Word of caution, once you start you have to finish as it really whitens the surface, use ONLY CLEAN WHITE RAGS, make sure you only wipe the vinyl surface,do a small area at a time, change out for a fresh rag as often as possible, don't saturate the area, don't stay in one area too long, give the cleaner time to evaporate and the vinyl time to recover, touch noting else when cleaning as you might smear that color into the white grain, keep it away from painted/dyed surfaces...
All the other "whitening" products pale in comparison
Mike
Re: White vinyl interior: best product, method for cleaning? [Re: DAYCLONA] #2487216
04/24/18 12:35 PM
04/24/18 12:35 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Zaino's interior cleaner.
Ron
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2487218
04/24/18 12:41 PM
04/24/18 12:41 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Fantastic . . . have used that on the white interior of my 74 Duster360 for years, using a scrub brush to even keep the stitching bright white !!! . . .
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2487220
04/24/18 12:46 PM
04/24/18 12:46 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Years ago I used the whitewall bleach stuff on a dirty white interior (years of sitting) and it was very effective. Had to be careful with it, as it seemed capable of actually melting the vinyl a bit. Had to air the car out afterwards.
Maybe better products have come along; I wonder if Simple Green would work well, I don't recall trying that.
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2487232
04/24/18 01:03 PM
04/24/18 01:03 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
We used to use spray 9 to clean vinyl seats, door panels etc. Pretty much spray and wipe right off with little effort. Doesn't hurt anything if it stays on longer.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: White vinyl interior: best product, method for cleaning? [Re: topside] #2487291
04/24/18 02:18 PM
04/24/18 02:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Simple Green is overrated, dish soap is a better product than SG
Re: White vinyl interior: best product, method for cleaning? [Re: DAYCLONA] #2487336
04/24/18 03:30 PM
04/24/18 03:30 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I found out Crown available at Walmart is a very good cleaner and safe
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: White vinyl interior: best product, method for cleaning? [Re: mopargem] #2487348
04/24/18 04:07 PM
04/24/18 04:07 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I tried several different cleaners on my convertible's white top over time and never had much success. Last year I had some work being done on it by a local Mopar shop, and he noticed the dirty top and asked if I wanted him to clean it for me. I said if it wouldn't take much time and run up my bill much more, go ahead.
When I got the car back, the top looked like new! He said he used Westley's Bleach white, and a lot of water to rinse it off. Then after he was finished, he used a vinyl preservative like Mothers.
I assume it would work equally well on interiors, though it would be best to remove the seats and do them out on the driveway or patio rather than while in the car.
Re: White vinyl interior: best product, method for cleaning? [Re: Silver70] #2487416
04/24/18 06:28 PM
04/24/18 06:28 PM
a12rag Offline
a12rag  Offline
Have also used Spray 9 with good success too ! . . .
Re: White vinyl interior: best product, method for cleaning? [Re: DAYCLONA] #2487803
04/25/18 02:53 PM
04/25/18 02:53 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Thanks Mike I'll cautiously give that a try up and funny thing the other day in the auto parts I looked at a can of that exact 3M product and said that might work.....naw, no way wink
Thanks everyone too, for the replies, more replies and experiences are appreciated.
Mike
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2488095
04/26/18 02:43 AM
04/26/18 02:43 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I've used hand cleaner and fairly soft scrub brush with good results. I figured if it's safe for your hands then it should be safe for the seats.
Re: White vinyl interior: best product, method for cleaning? [Re: rallye73] #2488169
04/26/18 11:14 AM
04/26/18 11:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Someone recommended using GOOP brand hand cleaner on white interior cleaning, I haven't had the chance to try it though?
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2488498
04/26/18 11:48 PM
04/26/18 11:48 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
My friend had good luck with Meguiar's #39 Heavy Duty Vinyl cleaner followed up by the #40 Vinyl and Rubber Cleaner / conditioner
inherited a 69 roadrunner from my grand pop.
Re: White vinyl interior: best product, method for cleaning? [Re: A12] #2488803
04/27/18 08:13 PM
04/27/18 08:13 PM
MO
cdp Offline
cdp  Offline
MO
Believe it or not, quick-n-brite worked really well on cleaning a white interior that had allot of mildew on it. I'd say a lanolin based cleaner, a soft scrub brush, and a cheap set of micro-fiber towels will do wonders.
