clutch problem on 68 rr #2488040
04/26/18 12:27 AM
04/26/18 12:27 AM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
i recently replaced clutch in a 68 rr 11inch, when clutch was pushed in all the way, the 3 fingers touched on the springs of the disc. so i replaced the pressure plate with diaphram type pressure plate, now the t.o. brng. is touching the pressure plate. Free play is 1 inch or so? any ideas are all t.o. brngs. the same for 23 spline trans?
Re: clutch problem on 68 rr [Re: fpmopar] #2488097
04/26/18 02:54 AM
04/26/18 02:54 AM
Washington
madscientist Offline
Washington
Disc is too thick. You may need to shim the pressure plate or get a thinner disc.
Re: clutch problem on 68 rr [Re: madscientist] #2488099
04/26/18 03:16 AM
04/26/18 03:16 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Or the disk is in backwards
Re: clutch problem on 68 rr [Re: fpmopar] #2488100
04/26/18 03:24 AM
04/26/18 03:24 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Can't get disc in backwards, won't fit.
Re: clutch problem on 68 rr [Re: NANKET] #2488101
04/26/18 03:27 AM
04/26/18 03:27 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Then why did my McLeod clutch disks come with a sticker on them that said "engine side" ?
Re: clutch problem on 68 rr [Re: fpmopar] #2488263
04/26/18 02:10 PM
04/26/18 02:10 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I cant be held responsible for that sticker.
Try to put one in backwards and let us know what happens.
Re: clutch problem on 68 rr [Re: fpmopar] #2488283
04/26/18 02:55 PM
04/26/18 02:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
It will go in backwards.Wont work.But it will bolt in.Rocky
Chrysler Firepower
Re: clutch problem on 68 rr [Re: NANKET] #2488396
04/26/18 06:24 PM
04/26/18 06:24 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Depends on the diameter of the recess in the flywheel where the bolts reside, if the diameter of the recess is large enough the disc can be installed backwards...thus the printed warning.
On most Mopars and on most discs the spring hub is too large to fit in the flywheel recess.
Re: clutch problem on 68 rr [Re: fpmopar] #2488424
04/26/18 08:07 PM
04/26/18 08:07 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
These are 11" parts. Disc hub sticks out further on one side, this side goes to the rear. Place the disc on the flywheel backwards with bolts installed and spinning it finds the springs of the disc hitting the bolt heads. Disc will not lay down flat on the flywheel. Can't imagine the noise this would cause, and destroy the hub in seconds.
Why the sticker? To reduce warranty claims and reduce calls to the tech line.
It all seems so easy on the bench, but laying under the car cold and wet can cause many problems.
Re: clutch problem on 68 rr [Re: NANKET] #2488887
04/27/18 11:45 PM
04/27/18 11:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've seen this before when the flywheel has been cut too thin.
It might be time for a new flywheel shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: clutch problem on 68 rr [Re: fourgearsavoy] #2489006
04/28/18 11:30 AM
04/28/18 11:30 AM
New York
rarefish Online content
rarefish  Online Content
New York
I had the same problem with a clutch that I bought for my 69 Dart. The fingers also hit the springs in the disc when I pushed the clutch pedal all the way down.
I too was told by many that I must have installed the disc in backwards, but I found out that would have been impossible as the disc hub would not fit into the recess of the fly wheel.
I took the clutch back out and measured the static height of the pressure plate and found that it was set too low for the thickness of the disc that came in the clutch kit.
The pictures show the difference in the clutch plate height that I had when comparing the new pressure plate to the old one I took out.
Re: clutch problem on 68 rr [Re: fpmopar] #2489528
04/29/18 02:52 PM
04/29/18 02:52 PM
pa.
dan9 Offline
dan9  Offline
pa.
I had the same problem with a new McCleod setup. McCleod sent me a new one. They are aware of this problem.
