DATA LOGGERS #2488370
04/26/18 05:43 PM
04/26/18 05:43 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I know that Race Pak is probably the most popular, but has anyone used the Autometer system?
Real Men shift for themselves
Re: DATA LOGGERS [Re: 1DGEMAN] #2488388
04/26/18 06:16 PM
04/26/18 06:16 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I'm going to suggest race pack.. seems to be a stable and safe way to go
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: DATA LOGGERS [Re: 1DGEMAN] #2488957
04/28/18 07:49 AM
04/28/18 07:49 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I'm going to stump up on a data logger sometime. I see a lot of Racepak stuff in the pits, even the supplier is hanging around giving help, carrying a few spares at the bigger meets. I also run an MSD Grid system, so racepak is a no brainer for me. Just gotta save up the pennies.
Re: DATA LOGGERS [Re: Tig] #2489040
04/28/18 12:55 PM
04/28/18 12:55 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I have a V300SD Racepak in my car it is painfully expensive every time a sensor is added to the system. Some of the latest fuel injection systems have excellent data logging capabilities. My best guess is that EFI systems will ultimately obsolete Racepak and hopefully bring the prices for logging down.
76 Duster work in progress
Re: DATA LOGGERS [Re: 1DGEMAN] #2489134
04/28/18 05:27 PM
04/28/18 05:27 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
RPM data loggers will do everything Racepak will do for less than half the cost and way better customer support. Unless you are running NHRA type points races with contingency money on the line, RPM Data loggers is the way to go. Even then, you would have to win a few big/points races to win enough contingency money back from Racepak to make their system cost effective...
Re: DATA LOGGERS [Re: Edge] #2489144
04/28/18 05:46 PM
04/28/18 05:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You could certainly do an EFI system to control your ignition and data log while still keeping the carb on the car.
I think it wouldn't be hard to be in an Megasquirt 3 system for your ignition and data logging for less money that you would spend on a race pack. If you need to add a dash you can buy a tablet at wal mart to use.
www.DIYAUTOTUNE.COM
68 Barracuda Formula S 340
