Caltrac with Sliders video #2487998
04/25/18 10:33 PM
04/25/18 10:33 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
I took this video Saturday, not sure if suspension is doing what it should or not. This was a 10.34 @ 129mph with a 1.44 60ft.
https://youtu.be/pykomRESf0M
Re: Caltrac with Sliders video [Re: nss guy] #2488047
04/26/18 12:50 AM
04/26/18 12:50 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Cool video. Do the sliders top out on the launch? Hard to tell.
Re: Caltrac with Sliders video [Re: nss guy] #2488050
04/26/18 12:58 AM
04/26/18 12:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Nice Vid, but at 57 sec the sliders bottom out and you can see the axel get lifted up nearly off the pavement. That's the purpose of these vids is to see this kind of stuff. Looks like the slider brackets need to go another inch forward or so. Better shock control could help or Fix it as well. up
Edit: Also right rear/rim or axel may be bent, slight wheel wobble going on. No biggie though.
Re: Caltrac with Sliders video [Re: nss guy] #2488051
04/26/18 12:59 AM
04/26/18 12:59 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
From the angle of the video it is hard to see for sure but it looks like the slider needs more forward travel. You have a lot of room at the back. Is that how Calvert recommends to install them? Is this a street strip car?
Real Men shift for themselves
Re: Caltrac with Sliders video [Re: nss guy] #2488055
04/26/18 01:11 AM
04/26/18 01:11 AM
P
Porter67 Offline
Porter67  Offline
P
Nice vid.
I use caltracks/sliders as well and to me it does look like they could be moved a tiny bit.
When setting them up they say to center them, but what they dont say so much is you need to be in full race weight and you need to compensate for the bit that the springs themselves will settle.
You could probably gain a 1/8 or better travel wise by dropping the springs and just using a bur/die grinder to make the slot longer without any cutting or welding.
Re: Caltrac with Sliders video [Re: nss guy] #2488056
04/26/18 01:12 AM
04/26/18 01:12 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I would start looking at better shocks to control the rear better .
Re: Caltrac with Sliders video [Re: a493demon] #2488060
04/26/18 01:26 AM
04/26/18 01:26 AM
Washington
madscientist Offline
Washington
^^^^^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^
Re: Caltrac with Sliders video [Re: nss guy] #2488061
04/26/18 01:26 AM
04/26/18 01:26 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can use some grease to verify your not maxing the sliders.How much front end travel you working with?Any prelosd??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Caltrac with Sliders video [Re: nss guy] #2488071
04/26/18 01:44 AM
04/26/18 01:44 AM
P
Porter67 Offline
Porter67  Offline
P
Ive had good luck with Qa1 doubles, cant say the difference between them and the calvert shocks because I never used the calvert shocks.
But ive always thought the calvert shocks were not much different then the ranchos I use on my 4x4 red boot and all in the box.
Re: Caltrac with Sliders video [Re: nss guy] #2488142
04/26/18 10:06 AM
04/26/18 10:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Id would agree I would be looking for a shock with more extension valving for sure. As for the slider question, it looks like they are running out of travel but a simple zip tie on the front will answer that question.
Re: Caltrac with Sliders video [Re: nss guy] #2488150
04/26/18 10:19 AM
04/26/18 10:19 AM
Ohio
lockjaw-express Offline
Ohio
Calvert told me to install mine at 70/30 on the slot...so the pin is more toward the rear. My car is street strip, and I have not bottomed out yet, and still have not gone to the strip yet.
Mark
Re: Caltrac with Sliders video [Re: nss guy] #2488158
04/26/18 10:43 AM
04/26/18 10:43 AM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Shocks were not full tight, 3 clicks away . I will tighten them up this weekend
Re: Caltrac with Sliders video [Re: nss guy] #2488159
04/26/18 10:46 AM
04/26/18 10:46 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nice vid. What setting did ya have the Calverts adjusted too?
Re: Caltrac with Sliders video [Re: nss guy] #2488185
04/26/18 11:49 AM
04/26/18 11:49 AM
Boise
Moparteacher Offline
Boise
The rear wraps up quite a bit on launch. I would figure more preload or tighter rebound setting on shocks.
Re: Caltrac with Sliders video [Re: a493demon] #2488219
04/26/18 12:56 PM
04/26/18 12:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would agree although I went a foot breakin 1.33 60 ft. w/slicks on 5-way Rancho's a while back but now run Shiloh's Vikings and have been a 1.34 60 ft pulling the ft up 2'on QTP's street tires. Better shock controll made my car come alive and hooks on the street now and my slider boxes are biased towards the rear and never bottom out in either direction............... beer If you locate the shocks to be more straight up than angled it may help even more cos it made a BIG difference on my Dart........ thumbs
Re: Caltrac with Sliders video [Re: nss guy] #2488484
04/26/18 10:53 PM
04/26/18 10:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What advantage do having sliders add?
Re: Caltrac with Sliders video [Re: ScottSmith_Harms] #2488521
04/27/18 12:44 AM
04/27/18 12:44 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would say helps give some side to side stability.. helps the suspension to react Freer and faster... lowers the car. I wish I could say reduces weight but that would be a lie..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Caltrac with Sliders video [Re: nss guy] #2490006
04/30/18 02:50 PM
04/30/18 02:50 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
Hey Jim,
Tightening the shocks must have helped! Congrats on the win.
http://classracer.com/classforum/showthread.php?s=f4fa1cd8a6b34a59f7477940753b32d7&t=69734
Re: Caltrac with Sliders video [Re: 65Dodge440] #2490091
04/30/18 06:38 PM
04/30/18 06:38 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Originally Posted By 65Dodge440
Hey Jim,
Thanks!
Re: Caltrac with Sliders video [Re: 65Dodge440] #2490107
04/30/18 07:25 PM
04/30/18 07:25 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Hey Jim,
http://classracer.com/classforum/showthread.php?s=f4fa1cd8a6b3y4a59f7477940753b32d7&t=69734
Wow, hard package to beat!
'63 Dodge 330
11.19 @ 121 mph
