Re: Caltrac with Sliders video
[Re: nss guy]
#2488050
04/26/18 12:58 AM
04/26/18 12:58 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Nice Vid, but at 57 sec the sliders bottom out and you can see the axel get lifted up nearly off the pavement. That's the purpose of these vids is to see this kind of stuff. Looks like the slider brackets need to go another inch forward or so. Better shock control could help or Fix it as well. Edit: Also right rear/rim or axel may be bent, slight wheel wobble going on. No biggie though.
[Re: nss guy]
#2488051
04/26/18 12:59 AM
04/26/18 12:59 AM
Posts: 608 TN
1DGEMAN
TN
From the angle of the video it is hard to see for sure but it looks like the slider needs more forward travel. You have a lot of room at the back. Is that how Calvert recommends to install them? Is this a street strip car?
Real Men shift for themselves
[Re: a493demon]
#2488060
04/26/18 01:26 AM
04/26/18 01:26 AM
Posts: 4,457 Washington
madscientist
Washington
I would start looking at better shocks to control the rear better . ^^^^^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^
[Re: nss guy]
#2488061
04/26/18 01:26 AM
04/26/18 01:26 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
You can use some grease to verify your not maxing the sliders.How much front end travel you working with?Any prelosd??
[Re: nss guy]
#2488142
04/26/18 10:06 AM
04/26/18 10:06 AM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Id would agree I would be looking for a shock with more extension valving for sure. As for the slider question, it looks like they are running out of travel but a simple zip tie on the front will answer that question.
[Re: a493demon]
#2488219
04/26/18 12:56 PM
04/26/18 12:56 PM
Thumperdart
State of confusion
I would start looking at better shocks to control the rear better . I would agree although I went a foot breakin 1.33 60 ft. w/slicks on 5-way Rancho's a while back but now run Shiloh's Vikings and have been a 1.34 60 ft pulling the ft up 2'on QTP's street tires. Better shock controll made my car come alive and hooks on the street now and my slider boxes are biased towards the rear and never bottom out in either direction............... If you locate the shocks to be more straight up than angled it may help even more cos it made a BIG difference on my Dart........
[Re: ScottSmith_Harms]
#2488521
04/27/18 12:44 AM
04/27/18 12:44 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I would say helps give some side to side stability.. helps the suspension to react Freer and faster... lowers the car. I wish I could say reduces weight but that would be a lie..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 65Dodge440]
#2490091
04/30/18 06:38 PM
04/30/18 06:38 PM
Posts: 1,443 central ohio
nss guy
central ohio
Hey Jim, Tightening the shocks must have helped! Congrats on the win.
Thanks!
[Re: 65Dodge440]
#2490107
04/30/18 07:25 PM
04/30/18 07:25 PM
Posts: 4,684 Wichita
GY3
Wichita
Wow, hard package to beat!
[Re: GY3]
#2490132
04/30/18 09:01 PM
04/30/18 09:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your sliders are mounted to rearward.. you want more forward travel.. if the shocks were tighter on extension it will help.. but the back half of the travel is pretty much wasted
[Re: MR_P_BODY]
#2490147
04/30/18 09:53 PM
04/30/18 09:53 PM
Posts: 126 Oregon
Jamie McGrath
Your sliders are mounted to rearward.. you want more forward travel.. if the shocks were tighter on extension it will help.. but the back half of the travel is pretty much wasted Yea, what he said.... I would slide them forward about another 1.5in and pocket them too drop the rear the same amount.
[Re: nss guy]
#2490165
04/30/18 10:53 PM
04/30/18 10:53 PM
MR_P_BODY
Thanks for all the input. Car is leaving pretty good, hate to mess to much. THis was from first rd. saturday
Its close now but it wouldnt take much to stall the movement.. its at the front of travel at its peak load but it might want a little more.. if you dont move it you'll never know if it can be better
