Head gasket question #2487213
04/24/18 12:27 PM
04/24/18 12:27 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am going to be installing a set of Eddy RPM heads on my motor and I will be using Fel-Pro 1009 head gaskets. The heads are new and the block has been decked. Would it be best to install the gaskets as-is or should I spray them with a gasket dressing such as Copper-Kote?
Re: Head gasket question [Re: 440mopar] #2487228
04/24/18 12:54 PM
04/24/18 12:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Lay that 1009 Head Gasket on your head and line up the head bolt holes to make sure the fire ring isn’t in the chamber. That’s been an issue with that gasket at times.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head gasket question [Re: 440mopar] #2487255
04/24/18 01:44 PM
04/24/18 01:44 PM
Which block are you building? The 1009 was designed for the smaller bore 426,383,(4.250 size)413 and 361 blocks(4.180), not for the larger 4.320 440 bores scope
I bought the 1009 for the 413 truck block build with the bore at 4.250 I'm assembling now with 440 source heads, they barely fit properly on it shruggy
Re: Head gasket question [Re: 440mopar] #2487261
04/24/18 01:51 PM
04/24/18 01:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
use the 8519 gasket. don't take a chance with 1009.
Re: Head gasket question [Re: Cab_Burge] #2487264
04/24/18 01:52 PM
04/24/18 01:52 PM
dogdays Offline
dogdays  Offline
Per the gasket manufacturers, gaskets go in dry.
Or if you think you know more than the guys who designed the gasket, go ahead and slather it with goop.
What the goop does is provide another liquid layer between gasket and surface.
The last engine I took apart had some sort of graphite colored stuff on each side of the gasket. It took real effort to scrape it all off the block and heads.
Note: There are some gasket holes on some engines that tend to leak either oil or water. On these engines, a light coating of Hylomar Blue just around the offending holes will keep the assembly from leaking.
R.
Re: Head gasket question [Re: Cab_Burge] #2487266
04/24/18 01:56 PM
04/24/18 01:56 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
It's a 400 block.
Re: Head gasket question [Re: 440mopar] #2487267
04/24/18 01:57 PM
04/24/18 01:57 PM
Don't use the 1009 on it tsk
Re: Head gasket question [Re: dogdays] #2487269
04/24/18 01:59 PM
04/24/18 01:59 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
"Or if you think you know more than the guys who designed the gasket, go ahead and slather it with goop."
I don't think I know more than the guys who designed the gasket. If I did I wouldn't be asking for advice.
Re: Head gasket question [Re: 440mopar] #2487274
04/24/18 02:02 PM
04/24/18 02:02 PM
I always put them on dry up
Re: Head gasket question [Re: 440mopar] #2487304
04/24/18 02:40 PM
04/24/18 02:40 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We had a 440 block that had a large chamfer. We couldn't use the 1009 gasket because it hung into the bore.
When we have used that gasket we always put it on dry.
Re: Head gasket question [Re: cl440] #2487324
04/24/18 03:11 PM
04/24/18 03:11 PM
PA.
"Little"John
"Little"John
PA.
The bore is easy to catch but a lot of guys never lay it on the head to do a test fitting to see the fire ring in the chamber
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head gasket question [Re: 440mopar] #2487331
04/24/18 03:14 PM
04/24/18 03:14 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
They didnt work on my Stealths which were the first set.I used the felpro marine gaskets.Fits perfect and have been on at least 6 years.rocky
Chrysler Firepower
Re: Head gasket question [Re: lewtot184] #2487345
04/24/18 04:04 PM
04/24/18 04:04 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The FP 8519 is NOT a performance intended head gasket... it simply has the additional spark plug stem holes.. as used on the common motorhome engines.
Re: Head gasket question [Re: therocks] #2487347
04/24/18 04:06 PM
04/24/18 04:06 PM
Mopar Mitch Offline
Mopar Mitch  Offline
The FP marine head gaskets have stainless steel instead of tin plate metal (both core and armor)... to prevent salt water rusting. The cylinder armor is also SS.. so that is better than the tin plate armor used on the standard head gasket (7891 PT).
Re: Head gasket question [Re: 440mopar] #2487350
04/24/18 04:12 PM
04/24/18 04:12 PM
Mopar Mitch Offline
Mopar Mitch  Offline
There is no need to apply any chemical to a fiber-faced gasket. Further, the FP gasket already has a pre-applied facial sealer simply to add release agent if/when ever removed. Read the instructions.
The bore diameter can be an issue... always safe to double-check both the head chamber and block chamfers... can be an issue with any gasket and any casting.
I was a former FP engineer.. I know the product and design.
Re: Head gasket question [Re: 440mopar] #2488228
04/26/18 01:09 PM
04/26/18 01:09 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
So which FelPro head gasket would suggest for a high performance application Mitch?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Head gasket question [Re: BloFish] #2488233
04/26/18 01:19 PM
04/26/18 01:19 PM
PA.
"Little"John
"Little"John
PA.
I used this one for a lot of 8 second passes with zero issues on my 440 based builds.
https://www.summitracing.com/parts/fel-17059/overview/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head gasket question [Re: 440mopar] #2488254
04/26/18 01:53 PM
04/26/18 01:53 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Has anyone tried the Superformance head gasket?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Head gasket question [Re: Mopar Mitch] #2488257
04/26/18 01:57 PM
04/26/18 01:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And why I've been running the Marine gasket for 16+ years.......... beer
Re: Head gasket question [Re: pittsburghracer] #2488266
04/26/18 02:20 PM
04/26/18 02:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Do these have a lock wire in them?
