Re: Head gasket question
[Re: 440mopar]
#2487228
04/24/18 12:54 PM
04/24/18 12:54 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lay that 1009 Head Gasket on your head and line up the head bolt holes to make sure the fire ring isn’t in the chamber. That’s been an issue with that gasket at times.
[Re: cl440]
#2487324
04/24/18 03:11 PM
04/24/18 03:11 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We had a 440 block that had a large chamfer. We couldn't use the 1009 gasket because it hung into the bore.
When we have used that gasket we always put it on dry. The bore is easy to catch but a lot of guys never lay it on the head to do a test fitting to see the fire ring in the chamber
[Re: 440mopar]
#2487331
04/24/18 03:14 PM
04/24/18 03:14 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
They didnt work on my Stealths which were the first set.I used the felpro marine gaskets.Fits perfect and have been on at least 6 years.rocky
Chrysler Firepower
[Re: lewtot184]
#2487345
04/24/18 04:04 PM
04/24/18 04:04 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The FP 8519 is NOT a performance intended head gasket... it simply has the additional spark plug stem holes.. as used on the common motorhome engines.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: therocks]
#2487347
04/24/18 04:06 PM
04/24/18 04:06 PM
Mopar Mitch
The FP marine head gaskets have stainless steel instead of tin plate metal (both core and armor)... to prevent salt water rusting. The cylinder armor is also SS.. so that is better than the tin plate armor used on the standard head gasket (7891 PT).
Mopar Mitch
[Re: 440mopar]
#2487350
04/24/18 04:12 PM
04/24/18 04:12 PM
Mopar Mitch
There is no need to apply any chemical to a fiber-faced gasket. Further, the FP gasket already has a pre-applied facial sealer simply to add release agent if/when ever removed. Read the instructions.
The bore diameter can be an issue... always safe to double-check both the head chamber and block chamfers... can be an issue with any gasket and any casting.
I was a former FP engineer.. I know the product and design.
Mopar Mitch
[Re: 440mopar]
#2488228
04/26/18 01:09 PM
04/26/18 01:09 PM
Posts: 16,474 On the run…
BloFish
On the run…
So which FelPro head gasket would suggest for a high performance application Mitch?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2488233
04/26/18 01:19 PM
04/26/18 01:19 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used this one for a lot of 8 second passes with zero issues on my 440 based builds. https://www.summitracing.com/parts/fel-17059/overview/
[Re: 440mopar]
#2488254
04/26/18 01:53 PM
04/26/18 01:53 PM
BloFish
On the run…
Has anyone tried the Superformance head gasket?
[Re: Mopar Mitch]
#2488257
04/26/18 01:57 PM
04/26/18 01:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
The FP marine head gaskets have stainless steel instead of tin plate metal (both core and armor)... to prevent salt water rusting. The cylinder armor is also SS.. so that is better than the tin plate armor used on the standard head gasket (7891 PT). And why I've been running the Marine gasket for 16+ years..........
