Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? #2485453
04/20/18 06:09 AM
04/20/18 06:09 AM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Just checked my 4 speed out of my 70 Road Runner. It does not have the 2 shifter mounting locations. Were some 70's just a single mount type? Numbers match my VIN on it.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2485455
04/20/18 06:20 AM
04/20/18 06:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the dual mount B & E-body manual transmission tailshaft & transmission crossmember mount location are new for '70 - all should have it twocents
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2485481
04/20/18 09:37 AM
04/20/18 09:37 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have a hemi four speed that came out of a low mileage 69 RT many years ago. It has TWO crossmember mount locations, one for the 69 and one for the 70. It only has one shifter mount location at the front. I bet yours is the same way. I was told it was it was a transion part to finish out the old style and getting ready for the new. I bet that is what you have. Look and see if you have two mounting pads.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: fastmark] #2485546
04/20/18 12:15 PM
04/20/18 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A friend has a late 69 build RR that have a trans that has the 2 trans mount pads, only the 69 location is drilled, and it only has the forward shifter location cast on it .
I'm going to ask the OP the stupid question ... is this the original trans to the car ?
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2485552
04/20/18 12:29 PM
04/20/18 12:29 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
He said his numbers match.
Another possibility is that someone changed the tail shaft in the past.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: Alaskan_TA] #2485563
04/20/18 12:43 PM
04/20/18 12:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks Barry I missed that somehow? That's why I said STUPID question ...
but I agree , if he has the numbers match mainhousing and the the wrong tailhousing no telling what was done in the past if he is not the original owner?
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: JohnRR] #2485933
04/21/18 04:11 AM
04/21/18 04:11 AM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Thanks for the input, I bought the car from the original owner in 1987, I do not know if he ever had the transmission out or worked on it. Yes, the vin matches the car so its the original transmission. I will put a couple of pictures up.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2485947
04/21/18 07:55 AM
04/21/18 07:55 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The tail HOUSING may have been changed. The tail shaft is inside the tail housing.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: NANKET] #2485972
04/21/18 09:50 AM
04/21/18 09:50 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Learn something new here almost daily. up
I was told years ago that the '70-up dual shifter locations was because they used one spot for B-bodies and the other for E-bodies. blush
Glad I never had occasion to argue that point (especially with my wife). wink
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: I_bleed_MOPAR] #2486077
04/21/18 02:32 PM
04/21/18 02:32 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Tim
That's true, they did use one spot for E bodies and one for B bodies
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: I_bleed_MOPAR] #2486877
04/23/18 04:33 PM
04/23/18 04:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tim
They did and it was for both body platforms , but also in a cost cutting operation they moved the crossmember mounting point to the same location as the 727, and 904, so they only needed to build one transmission crossmember.
What Chrysler did at one point late in the 69 model year is start recasting the tailhousing for the upcoming production change and cast a tailhousing with both crossmember mounting locations , but only drilled and tapped the 69 location, but oddly the tailhousing only had the forward shifter mounting point and not the E body rear location.
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: JohnRR] #2486908
04/23/18 05:28 PM
04/23/18 05:28 PM
Buford, GA
Buford, GA
Got it now. 2 shifter mounting points and 2 trans. mount points.
Like I said, learn something new almost every day here (even someone as slow as I am sometimes wink ). boogie
Tim
'71 Charger 383/727
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2487049
04/23/18 11:57 PM
04/23/18 11:57 PM
Chicago
PurpleBeeper Offline
Chicago
OK, well my numbers matching 70 b-body A-833 (Jan 1970 build in St.Louis) has the traditional one set of cross-member mounting holes & two sets of shifter mounting holes.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: JohnRR] #2487125
04/24/18 06:35 AM
04/24/18 06:35 AM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Tim
That is just like this one, it has the 2 crossmember spots but just has the forward shifter mount. I don't have the fender tag, not sure when it was built.
THANKS!
Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location? [Re: 70X] #2487314
04/24/18 02:58 PM
04/24/18 02:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The different crossmember was for automatic VS 4 speed in B bodies. 1969 and older.
The 727 and 904 use the same crossmember in B bodies.
