Need help identifying Mopar performance part number
#2486756
04/23/18 11:45 AM
04/23/18 11:45 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I was wondering if someone could identify these part numbers for me these parts were made in approximately year 1999 or 2000.. # p5007644.. # P 4529710.. # p4532907..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Need help identifying Mopar performance part number
[Re: WHITEDART]
#2486775
04/23/18 12:32 PM
04/23/18 12:32 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I didn't find anything on the top one other than it is a crankshaft.
The second one shows to be a 3.51 stroke crank, there is one on ebay.
The third is an R3 block, Jegs shows to have 10 on ebay.
68 Barracuda Formula S 340
[Re: 1969ronnie]
#2486872
04/23/18 04:28 PM
04/23/18 04:28 PM
WHITEDART
bean town ....Ca
hi white, the P 4529710 is a forged A engine crankshaft with a 3.51" stroke 8 bolt flange. mopar has a chart to tell you cubic inch depending on bore size. lunch time over. will check other 2 #s later. ronnie thank you guys for all your help it is greatly appreciated.. wouldn't you know it wasn't that long ago I just threw away all those old catalogs
[Re: WHITEDART]
#2486910
04/23/18 05:36 PM
04/23/18 05:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was wondering if someone could identify these part numbers for me these parts were made in approximately year 1999 or 2000.. # p5007644.. # P 4529710.. # p4532907.. Yep.. the P5007644 shows to be 3.79 billet crank with 6 bolt flange with 318/340 mains.. (I still own 2 of these cranks... The P452971 is a forged 3.51 stoke crank with a 8 bolt flange.. 318/340 mains.. I dont show a listing of the 4532907
[Re: MR_P_BODY]
#2486932
04/23/18 06:36 PM
04/23/18 06:36 PM
WHITEDART
bean town ....Ca
the last number is off of an R3 block that the extra head bolts are cut off of it also has been drilled for a 59 degree lifter.. and appears to be shorter than stock
