Need help identifying Mopar performance part number #2486756
04/23/18 11:45 AM
04/23/18 11:45 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I was wondering if someone could identify these part numbers for me these parts were made in approximately year 1999 or 2000..
# p5007644..
# P 4529710..
# p4532907..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486775
04/23/18 12:32 PM
04/23/18 12:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I didn't find anything on the top one other than it is a crankshaft.
The second one shows to be a 3.51 stroke crank, there is one on ebay.
The third is an R3 block, Jegs shows to have 10 on ebay.
68 Barracuda Formula S 340
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486859
04/23/18 03:25 PM
04/23/18 03:25 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi white, the P 4529710 is a forged A engine crankshaft with a 3.51" stroke 8 bolt flange. mopar has a chart to tell you cubic inch depending on bore size. lunch time over. will check other 2 #s later. ronnie
Re: Need help identifying Mopar performance part number [Re: 1969ronnie] #2486872
04/23/18 04:28 PM
04/23/18 04:28 PM
bean town ....Ca
W
W
bean town ....Ca
thank you guys for all your help it is greatly appreciated.. wouldn't you know it wasn't that long ago I just threw away all those old catalogs runaway
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486881
04/23/18 04:38 PM
04/23/18 04:38 PM
1969ronnie Offline
1969ronnie  Offline
hi white, don't get rid of your old books... hey the P5007644 shows a max strength, strongest material available for high performance applications A engine "Billet solid steel 4340" crankshaft " with a 3.79" stroke 6 bolt flange . later, ronnie chargerwork
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486910
04/23/18 05:36 PM
04/23/18 05:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
# p5007644..
# P 4529710..
# p4532907..
Yep.. the P5007644 shows to be 3.79 billet crank
with 6 bolt flange with 318/340 mains.. (I still
own 2 of these cranks...
The P452971 is a forged 3.51 stoke crank with a
8 bolt flange.. 318/340 mains.. I dont show a
listing of the 4532907
wave
Re: Need help identifying Mopar performance part number [Re: MR_P_BODY] #2486932
04/23/18 06:36 PM
04/23/18 06:36 PM
bean town ....Ca
W
W
bean town ....Ca
the last number is off of an R3 block that the extra head bolts are cut off of it also has been drilled for a 59 degree lifter.. and appears to be shorter than stock
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486942
04/23/18 07:11 PM
04/23/18 07:11 PM
dogdays Offline
dogdays  Offline
Tasca Parts has them listed at $767.36. Wow!
R.
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2486947
04/23/18 07:29 PM
04/23/18 07:29 PM
dogdays Offline
dogdays  Offline
I believe it's a 9.2" block. Considering a smallblock chevy is 9.025 and the GIII Hemi and LS motors are both 9.24, it would seem that it is possible to go over 400 cubic inches with one. Intake manifolds and possibly camshafts will be the problem.
R.
Re: Need help identifying Mopar performance part number [Re: WHITEDART] #2487025
04/23/18 11:03 PM
04/23/18 11:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
P4532907 was a block with a list price of $939. There are none in dealer or warehouse inventory.
Re: Need help identifying Mopar performance part number [Re: J_BODY] #2487303
04/24/18 02:40 PM
04/24/18 02:40 PM
dogdays Offline
dogdays  Offline
Yup. Just like all other Mopar LA blocks, vaporware. I was fooled by the dozen or so hits I got on that number.
R.
