Re: Pics of 8" or 10" Steelies with 295/50R15 tires?
[Re: PAINT IT BLACK]
#248642
03/09/09 07:49 PM
03/09/09 07:49 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
From another thread. moparts member Mopar-addiction 5.5 on a 10 inch
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#248643
03/09/09 07:55 PM
03/09/09 07:55 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Black_Sheep 's fronts 235/70R-15 on 15x7 wheels rears 295/65R-15 on 15x10 wheels But I think the rear is a little high to make this fit with this tire. That is if this is still the same tire below.
Allen
#248644
03/09/09 08:07 PM
03/09/09 08:07 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
That's not Topside's car?
#248645
03/09/09 08:09 PM
03/09/09 08:09 PM
PAINT IT BLACK
Houston Texas
Black_Sheep 's
Dang that's a bad@$$ car. I like the rake... Do you have a side pick of that car?
#248647
03/09/09 08:21 PM
03/09/09 08:21 PM
Posts: 9,887 USA
CrAlt
USA
So 15x10 with 5.5 BS fits with out mods on a 68-70 B-body?
I put new springs on my coronet and now the 255's on cop rims look small. Was thinking of putting them up front and getting some bigger tires/rims for the back.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: CrAlt]
#248649
03/09/09 08:29 PM
03/09/09 08:29 PM
Posts: 7,759 So Cal
HealthServices
So Cal
For the most part I have seen them fit but I also hear some people have rubbing and needed 1/8 spacers on one side or the other. Other than tire width, I can only assume it is due to:
Tire height (not everyone likes the stink bug look) and Ma Mopars' tolerances back then.
This one rubbed with passengers and when turning but I believe it was actually a tad larger than 295/60-R15 or their own version of that size. It was with 15X10 with 5.5 inch backspace though.
Allen
#248650
03/09/09 08:32 PM
03/09/09 08:32 PM
PAINT IT BLACK
Houston Texas
What size are those on the (green?) above car with the Hoosiers? 10"/5.5 bs?
#248651
03/09/09 08:38 PM
03/09/09 08:38 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I think he said it was 315? but it was a while ago and I forgot to write it down. It was on BK's forum before the 'Change' and the forum has not been the same since then.
Actually I think there wasn't a metric size to them. So they may be bias plys
Allen
#248653
03/09/09 08:52 PM
03/09/09 08:52 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I believe he was using one of the quck time tires. So there is a big selection of sizes.
P275/50D-15 P295/60D-15 P295/50D-15 P325/50D-15 28x11.50-15LT 28x13.50-15LT 28x14.50-15LT 29x11.50-15LT 29x13.50-15LT 29x14.50-15LT
Allen
#248654
03/09/09 09:03 PM
03/09/09 09:03 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
On their site they show a 275/60 (I run this on an 8" now, and know I wouldn't like it on a 10"), a 275/50, and a 295/65... so of the three, only the 295/65 sounds like it will work for me.
I've got a pair of new 295/65 in my garage that I used for test fitting on my 64 Dodge. PM if you decide you want that size, we might be able to work something out. BFG discontinued that size a year or two ago.
