Pics of 8" or 10" Steelies with 295/50R15 tires? #248637
03/09/09 04:45 PM
03/09/09 04:45 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
Got any pics? 10" with 295's should fit on a '70 B body, right?
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248638
03/09/09 05:07 PM
03/09/09 05:07 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think 325/50 R15 that BFG does not make any more.
5.5 backspace? This is from Spring fling a couple years ago.
This is mine with 8.5 inch and 295/50R15 wrong offset at 4.5 inches
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248639
03/09/09 05:27 PM
03/09/09 05:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
295/50R15 T/As on 15x8, 4.5BS on the back of my RR. Fronts are 265/50R15 on same size wheel.
8" is a bit narrow for a 295/50, and I think my car would look better with a 60 series tire.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: topside] #248640
03/09/09 05:43 PM
03/09/09 05:43 PM
So Cal
So Cal
The next size taller is the 295/65R15 and that is a little too tall. So tall (29.6") it will rub.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: topside] #248641
03/09/09 07:29 PM
03/09/09 07:29 PM
Houston Texas
Houston Texas
I think your blue RR looks good with those tires.
I currently have 8" Torq Thrust D's with what I think is probably 4.5" BS. 295/50R15 Firehawks. I was thinking of using these tires with some steelies (for a change of pace) and swapping the tires on the Torq Thrust to something else (BFG drag radials on the rear).
Something's just a little off about my rear wheels, and I think it is one of two things: Maybe I am used to my 60 series tires on the Cuda and these 295/50's are just a little too low profile.... OR I need to lower the rear and close the wheel well up a bit. I think that is why the blue RR looks good - because the wheel openings are lower on a RR than a Bee.
I am changing the rear springs anyway... I might have them de-arched to get the look I want.
So I'd really like to see some 10" steelies with 295/50's on them....anyone?
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248642
03/09/09 07:49 PM
03/09/09 07:49 PM
So Cal
So Cal
From another thread.
moparts member Mopar-addiction 5.5 on a 10 inch
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248643
03/09/09 07:55 PM
03/09/09 07:55 PM
So Cal
So Cal
Black_Sheep 's
fronts 235/70R-15 on 15x7 wheels
rears 295/65R-15 on 15x10 wheels
But I think the rear is a little high to make this fit with this tire. That is if this is still the same tire below.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248644
03/09/09 08:07 PM
03/09/09 08:07 PM
Houston Texas
Houston Texas
That's not Topside's car?
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248645
03/09/09 08:09 PM
03/09/09 08:09 PM
Houston Texas
Houston Texas
Black_Sheep 's
Dang that's a bad@$$ car. I like the rake... Do you have a side pick of that car?
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248646
03/09/09 08:16 PM
03/09/09 08:16 PM
Houston Texas
Houston Texas
Nevermind, I just found his website and got plenty of pics....
I think that tire is pushing it I suppose. Looks super mean on his black GTX, but maybe I want a little less tire on my car. What I am trying to avoid specifically is the perception of TOO DEEP of a wheel from the outside. I like the depth of my wheels now, but I now I have some room on the back side. In other words, I don't want to be coming within hairs of rubbing the quarter...
That car sure looks good from behind though!
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248647
03/09/09 08:21 PM
03/09/09 08:21 PM
USA
CrAlt Offline
CrAlt  Offline
USA
So 15x10 with 5.5 BS fits with out mods on a 68-70 B-body?
I put new springs on my coronet and now the 255's on cop rims look small. Was thinking of putting them up front and getting some bigger tires/rims for the back.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248648
03/09/09 08:21 PM
03/09/09 08:21 PM
So Cal
So Cal
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: CrAlt] #248649
03/09/09 08:29 PM
03/09/09 08:29 PM
So Cal
So Cal
For the most part I have seen them fit but I also hear some people have rubbing and needed 1/8 spacers on one side or the other. Other than tire width, I can only assume it is due to:
Tire height (not everyone likes the stink bug look) and Ma Mopars' tolerances back then.
This one rubbed with passengers and when turning but I believe it was actually a tad larger than 295/60-R15 or their own version of that size. It was with 15X10 with 5.5 inch backspace though.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248650
03/09/09 08:32 PM
03/09/09 08:32 PM
Houston Texas
Houston Texas
What size are those on the (green?) above car with the Hoosiers? 10"/5.5 bs?
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248651
03/09/09 08:38 PM
03/09/09 08:38 PM
So Cal
So Cal
I think he said it was 315? but it was a while ago and I forgot to write it down. It was on BK's forum before the 'Change' and the forum has not been the same since then.
Actually I think there wasn't a metric size to them. So they may be bias plys
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: HealthServices] #248652
03/09/09 08:46 PM
03/09/09 08:46 PM
Houston Texas
Houston Texas
On their site they show a 275/60 (I run this on an 8" now, and know I wouldn't like it on a 10"), a 275/50, and a 295/65... so of the three, only the 295/65 sounds like it will work for me.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248653
03/09/09 08:52 PM
03/09/09 08:52 PM
So Cal
So Cal
I believe he was using one of the quck time tires. So there is a big selection of sizes.
P275/50D-15
P295/60D-15
P295/50D-15
P325/50D-15
28x11.50-15LT
28x13.50-15LT
28x14.50-15LT
29x11.50-15LT
29x13.50-15LT
29x14.50-15LT
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: PAINT IT BLACK] #248654
03/09/09 09:03 PM
03/09/09 09:03 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I've got a pair of new 295/65 in my garage that I used for test fitting on my 64 Dodge. PM if you decide you want that size, we might be able to work something out. BFG discontinued that size a year or two ago.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: 64Post] #248655
03/09/09 09:31 PM
03/09/09 09:31 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
These are 305/50/15 on cop wheels
They replaced the 295's that were there before.
Re: Pics of 8" or 10" Steelies with 295/50R15 tires? [Re: dave571] #248656
03/13/09 01:33 PM
03/13/09 01:33 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
These are 29 x 12.5 Sportsmans with 8" steel wheels - 4.5" Backspace. There is about 3/4" each side clearance. I have original H/D springs and quarters are original. 70 Bees and Coronets have a lot of room. I got sick of looking at 14 x 5.5 w/26" tall skinny tires while I'm finishing it in the garage. This gave me some motivation
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
