Any W2 W5 Experts ? #2485075
04/19/18 01:12 PM
04/19/18 01:12 PM
Zumbrota,MN
als499 Offline OP
als499  Offline OP
Zumbrota,MN
I picked up these heads recently and were told they were w5 , but they look a little different to me. They have no casting #s or manufacturer name. They are aluminum rectangle intake port and D-port exhaust, any help would be appreciated , Thanks!
Re: Any W2 W5 Experts ? [Re: als499] #2485088
04/19/18 01:25 PM
04/19/18 01:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Could be Batten aluminium w-2.
Re: Any W2 W5 Experts ? [Re: als499] #2485095
04/19/18 01:55 PM
04/19/18 01:55 PM
Guitar Jones Online laugh2
Definitely not W5's
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Any W2 W5 Experts ? [Re: als499] #2485097
04/19/18 01:59 PM
04/19/18 01:59 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
They look like a Diamond W2 go to shadydell web site Ryan has all the heads posted over there
Re: Any W2 W5 Experts ? [Re: scottb] #2485215
04/19/18 06:45 PM
04/19/18 06:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They look like the Batten ones.. I never seen
the Diamond ones in person so I cant say on
those but they arent W-5.. W-5s have a W-5
on them
wave
Re: Any W2 W5 Experts ? [Re: MR_P_BODY] #2485225
04/19/18 07:13 PM
04/19/18 07:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I had a set of Battan heads on my flowbench years ago and was shocked by their numbers. Problem was this set was FULL and I mean FULL of old crack epoxy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Any W2 W5 Experts ? [Re: als499] #2485239
04/19/18 07:46 PM
04/19/18 07:46 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Arringtons
Re: Any W2 W5 Experts ? [Re: als499] #2485315
04/19/18 10:41 PM
04/19/18 10:41 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I agree...look like Arringtons but more pics would help. They are basically the predecessor to the W7s.
Re: Any W2 W5 Experts ? [Re: als499] #2485326
04/19/18 11:09 PM
04/19/18 11:09 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
If there Arringtons make sure to have them pressure tested
Re: Any W2 W5 Experts ? [Re: dizuster] #2485328
04/19/18 11:12 PM
04/19/18 11:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Kinda the predecessor to the small block Indy head
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Any W2 W5 Experts ? [Re: als499] #2485369
04/20/18 12:24 AM
04/20/18 12:24 AM
P
Porter67 Offline
Porter67  Offline
P
I know of and have seen two other sets, both sets not serviceable from mods and cracks.
I hope if you paid much for them they had test paperwork and if your going to use them id surly get them looked over well and tested as mentioned.
Good conversation/history parts but actually using them might be more hastle then its worth.
No such things as gently used on them old heads.
How jacked are the chambers? Probably o ringed as well.
Re: Any W2 W5 Experts ? [Re: als499] #2485590
04/20/18 01:22 PM
04/20/18 01:22 PM
Zumbrota,MN
als499 Offline OP
als499  Offline OP
Zumbrota,MN
I'm thinking they are Diamond rectangle port W2 , the Battans appear to have freezeplugs on the end and these do not. They were o-ringed at some point and 1 chamber needs to be repaired.
Re: Any W2 W5 Experts ? [Re: als499] #2485602
04/20/18 02:01 PM
04/20/18 02:01 PM
fla
ss/la Offline
ss/la  Offline
fla
they are not diamonds. diamond has a square exhaust port I had a set that came off of a comp dragster
Re: Any W2 W5 Experts ? [Re: ss/la] #2485610
04/20/18 02:10 PM
04/20/18 02:10 PM
Zumbrota,MN
als499 Offline OP
als499  Offline OP
Zumbrota,MN
It looks like Diamond made W2 heads with square or D-shaped exhaust ports. Found both styles on forabodies. https://www.forabodiesonly.com/mopar/thr...diamond.360464/
Re: Any W2 W5 Experts ? [Re: als499] #2486031
04/21/18 12:39 PM
04/21/18 12:39 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
They are for sure Diamonds. Look on top of the intake runner, there should be a P435.... casting number. I have a set also... that need lots of work, but they are a serious small block head!! Ive got a few intake manifolds if you need one
