Slimmest Electric Fan Available #2485675
04/20/18 04:47 PM
04/20/18 04:47 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Just wondering if anyone has found a very very slim electric cooling fan (push or pull) . . . I need something 2" or slimmer . . .
Thanks,
Mark
Re: Slimmest Electric Fan Available [Re: a12rag] #2485688
04/20/18 05:09 PM
04/20/18 05:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Spal and Mishimoto have some fans in the 2"-2 1/16"-2 3/8" range depends on diameter required, you might end up having to mount 2 because fans in the 2" thick range are 6" to 12" max in dia... generally, hopefully others might chime in with other info?
Mike
Re: Slimmest Electric Fan Available [Re: a12rag] #2485739
04/20/18 07:34 PM
04/20/18 07:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Delta Pag makes some nice looking very thin stuff. Not cheap but very nice.
https://deltapag.com/
68 Barracuda Formula S 340
Re: Slimmest Electric Fan Available [Re: a12rag] #2485824
04/20/18 10:22 PM
04/20/18 10:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If you need clearance in the middle for the water pump. How about a dual fan set up?
Re: Slimmest Electric Fan Available [Re: Magnum] #2485826
04/20/18 10:31 PM
04/20/18 10:31 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yep, my dual is pretty thin there.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Slimmest Electric Fan Available [Re: a12rag] #2486034
04/21/18 12:51 PM
04/21/18 12:51 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Fans out of a Neon are thin and move a ton of air. $20 to $40 at the recyclers.
Mo' Farts
Moderated by "tbagger".
Re: Slimmest Electric Fan Available [Re: a12rag] #2486172
04/21/18 07:59 PM
04/21/18 07:59 PM
a12rag Offline OP
a12rag  Offline OP
Thanks for the ideas . . . not for a mopar, for a 64 falcon with 6cylinder. Not really a cooling issue, it is more of an "extra hp" . . . don't like heading down the road at WOT to keep up to 65-70mph traffic !!! . . . figure removing the existing 4 blade fixed fan should give the ole machine a "little" more oomph . . . very very limited to room between rad & water pump or rad and grille in front . . . not a very large rad either . . . like idea of a brush type . . . I know the Ford 200cid 6 is really limited by the 1bbl carb . . . but just thought the fan would give it that little extra. But they never built this 6cylinder to be a rocket - the intake is cast into the head, so no choice on carb !!! . . . DUH . . .no wonder the slant 6 runs away from the Ford 6 !!! . . . .
Re: Slimmest Electric Fan Available [Re: a12rag] #2486364
04/22/18 12:34 PM
04/22/18 12:34 PM
moparx Offline
moparx  Offline
i'm not a fan [pun intended ! biggrin] of aftermarket fans, and if any way possible, choose factory items of your choice of manufacturer. the main reason, is aftermarket fans may, or [usually] may not blow [another intended pun !] what cfm they claim, while OEM fans move a ton of air, plus they are way more durable [even if made in elcheapistan] than imported aftermarket fans. only two things that are a must when using an electric fan. use a RELAY with wiring to match the fan of your choice, as some [most] OEM fans have a rather high start up electrical demand. and #2, make sure your present electrical system [alternator and wiring harness] is up to the task of keeping up with the fan's demand, plus the rest of your electrical needs. just my opinion after fixing electrical problems for over 40yrs. your mileage may vary....
beer
Re: Slimmest Electric Fan Available [Re: a12rag] #2486658
04/23/18 01:20 AM
04/23/18 01:20 AM
a12rag Offline OP
a12rag  Offline OP
Appreciate the input . . . I am in the electrical industry, and definitely agree with you on the relay and alternator/wiring comments !!! Actually I have already changed the headlights to a relay so they get full voltage (did same on my 70 sport satellite too) . . .
