Re: Slimmest Electric Fan Available
[Re: a12rag]
#2485739
04/20/18 07:34 PM
04/20/18 07:34 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Delta Pag makes some nice looking very thin stuff. Not cheap but very nice. https://deltapag.com/
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Magnum]
#2485826
04/20/18 10:31 PM
04/20/18 10:31 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If you need clearance in the middle for the water pump. How about a dual fan set up? Yep, my dual is pretty thin there.
[Re: a12rag]
#2486034
04/21/18 12:51 PM
04/21/18 12:51 PM
Posts: 5,997 Salem
Grizzly
Moparts Proctologist
Salem
Fans out of a Neon are thin and move a ton of air. $20 to $40 at the recyclers.
Mo' Farts
Moderated by "tbagger".
[Re: a12rag]
#2486364
04/22/18 12:34 PM
04/22/18 12:34 PM
Posts: 19,241 north of coder
moparx
i'm not a fan [pun intended ! ] of aftermarket fans, and if any way possible, choose factory items of your choice of manufacturer. the main reason, is aftermarket fans may, or [usually] may not blow [another intended pun !] what cfm they claim, while OEM fans move a ton of air, plus they are way more durable [even if made in elcheapistan] than imported aftermarket fans. only two things that are a must when using an electric fan. use a RELAY with wiring to match the fan of your choice, as some [most] OEM fans have a rather high start up electrical demand. and #2, make sure your present electrical system [alternator and wiring harness] is up to the task of keeping up with the fan's demand, plus the rest of your electrical needs. just my opinion after fixing electrical problems for over 40yrs. your mileage may vary....
