Re: Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location?
[Re: fastmark]
#2485546
04/20/18 12:15 PM
04/20/18 12:15 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I have a hemi four speed that came out of a low mileage 69 RT many years ago. It has TWO crossmember mount locations, one for the 69 and one for the 70. It only has one shifter mount location at the front. I bet yours is the same way. I was told it was it was a transion part to finish out the old style and getting ready for the new. I bet that is what you have. Look and see if you have two mounting pads. A friend has a late 69 build RR that have a trans that has the 2 trans mount pads, only the 69 location is drilled, and it only has the forward shifter location cast on it . I'm going to ask the OP the stupid question ... is this the original trans to the car ?
[Re: Alaskan_TA]
#2485563
04/20/18 12:43 PM
04/20/18 12:43 PM
JohnRR
U.S.S.A.
He said his numbers match.
Another possibility is that someone changed the tail shaft in the past. Thanks Barry I missed that somehow? That's why I said STUPID question ... but I agree , if he has the numbers match mainhousing and the the wrong tailhousing no telling what was done in the past if he is not the original owner?
[Re: NANKET]
#2485972
04/21/18 09:50 AM
04/21/18 09:50 AM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Learn something new here almost daily. I was told years ago that the '70-up dual shifter locations was because they used one spot for B-bodies and the other for E-bodies. Glad I never had occasion to argue that point (especially with my wife). Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2486077
04/21/18 02:32 PM
04/21/18 02:32 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Learn something new here almost daily. I was told years ago that the '70-up dual shifter locations was because they used one spot for B-bodies and the other for E-bodies. Glad I never had occasion to argue that point (especially with my wife). Tim That's true, they did use one spot for E bodies and one for B bodies
[Re: I_bleed_MOPAR]
#2486877
04/23/18 04:33 PM
04/23/18 04:33 PM
JohnRR
U.S.S.A.
Learn something new here almost daily. I was told years ago that the '70-up dual shifter locations was because they used one spot for B-bodies and the other for E-bodies. Glad I never had occasion to argue that point (especially with my wife). Tim They did and it was for both body platforms , but also in a cost cutting operation they moved the crossmember mounting point to the same location as the 727, and 904, so they only needed to build one transmission crossmember. What Chrysler did at one point late in the 69 model year is start recasting the tailhousing for the upcoming production change and cast a tailhousing with both crossmember mounting locations , but only drilled and tapped the 69 location, but oddly the tailhousing only had the forward shifter mounting point and not the E body rear location.
[Re: JohnRR]
#2486908
04/23/18 05:28 PM
04/23/18 05:28 PM
I_bleed_MOPAR
Buford, GA
Got it now. 2 shifter mounting points and 2 trans. mount points. Like I said, learn something new almost every day here (even someone as slow as I am sometimes ). Tim
[Re: 70X]
#2487049
04/23/18 11:57 PM
04/23/18 11:57 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
OK, well my numbers matching 70 b-body A-833 (Jan 1970 build in St.Louis) has the traditional one set of cross-member mounting holes & two sets of shifter mounting holes.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: JohnRR]
#2487125
04/24/18 06:35 AM
04/24/18 06:35 AM
Posts: 154 Missouri
70X
Missouri
Learn something new here almost daily. I was told years ago that the '70-up dual shifter locations was because they used one spot for B-bodies and the other for E-bodies. Glad I never had occasion to argue that point (especially with my wife). Tim They did and it was for both body platforms , but also in a cost cutting operation they moved the crossmember mounting point to the same location as the 727, and 904, so they only needed to build one transmission crossmember. What Chrysler did at one point late in the 69 model year is start recasting the tailhousing for the upcoming production change and cast a tailhousing with both crossmember mounting locations , but only drilled and tapped the 69 location, but oddly the tailhousing only had the forward shifter mounting point and not the E body rear location. That is just like this one, it has the 2 crossmember spots but just has the forward shifter mount. I don't have the fender tag, not sure when it was built. THANKS!
