rebuild kits for carbs
#248542
03/09/09 03:28 PM
03/09/09 03:28 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hi guys first time on the A12 board My question is when rebuilding all three carbs.and replacing the large diaphragms is there a company that will sell me a complete kit with only the things I need? Thank you Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: rebuild kits for carbs
[Re: fourgearsavoy]
#248543
03/09/09 06:17 PM
03/09/09 06:17 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Gus
I think your best bet is to get with member ScottSmith Harms
[Re: fourgearsavoy]
#248544
03/09/09 09:11 PM
03/09/09 09:11 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Buy (3) holley kits and (2) outer diaphragms and you should be set. They are not too expensive and you won't have many leftover items.
Al & Sheila
[Re: 3twos]
#248546
03/10/09 07:47 PM
03/10/09 07:47 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I don't think the kits come with diaphragms for the outboards? Those are Holley parts and I don't know if you can still get them?
[Re: RoadRunnerJD]
#248547
03/11/09 05:37 PM
03/11/09 05:37 PM
Posts: 1,495 Fort Workin Tx
Day2Runner
Fort Workin Tx
they dont also get some spring kits start with purple heres some #s i just pulled out of my 6bbl parts stash
pure holly renew kit 3 -396 diaphragms 135-6 spring kit 28-13
[Re: superwrench]
#248549
03/12/09 06:04 PM
03/12/09 06:04 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
Go on Ebay motors, under parts/accessories, type in six pack carbs. Down near the bottom there is a vendor called thepartsladi. Click on her name. She sells the correct Holley kits, 3 for $75, best price I have found. She may also have the diaphragms, I believe she does, but if she does not, other vendors on that page have them listed. Hope this helps! Lee.
[Re: RoadRunnerJD]
#248550
03/12/09 06:39 PM
03/12/09 06:39 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
John,sure you can and they are cheap if you know where to look.
[Re: 62maxwgn]
#248551
03/13/09 08:14 AM
03/13/09 08:14 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
showoff ...
