Anyone know if there are 340 heat riser kits available? #2483934
04/16/18 11:05 PM
04/16/18 11:05 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone know if there is a reproduction RH exhaust manifold heat riser kit available for a stock 340 setup (69-70 A-Body)?
Re: Anyone know if there are 340 heat riser kits available? [Re: vinnyd76] #2484417
04/17/18 11:05 PM
04/17/18 11:05 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
May have an nos one but would have to look.
Re: Anyone know if there are 340 heat riser kits available? [Re: vinnyd76] #2484503
04/18/18 09:03 AM
04/18/18 09:03 AM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
Try Neil Jenks at dynamicrenovations.net. Saw a complete set at mopar nationals that even included the anti-rattle spring. Nice pieces.
Re: Anyone know if there are 340 heat riser kits available? [Re: Aar1064] #2484506
04/18/18 09:44 AM
04/18/18 09:44 AM
Poland, Ohio 44514
captainjack Offline
captainjack  Offline
Poland, Ohio 44514
The repro by Jenks is excellent as I purchased one a few years ago at the Nats.
Re: Anyone know if there are 340 heat riser kits available? [Re: captainjack] #2484520
04/18/18 10:31 AM
04/18/18 10:31 AM
Aar1064 Offline
Aar1064  Offline
I checked website and they aren't listed but to my knowledge, never have been. A phone call may be in order.
Re: Anyone know if there are 340 heat riser kits available? [Re: vinnyd76] #2484576
04/18/18 12:12 PM
04/18/18 12:12 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i bought a nos one on ebay for my 71. seems to be lots of 71+ there but havent looked for earlier versions.
Re: Anyone know if there are 340 heat riser kits available? [Re: vinnyd76] #2484578
04/18/18 12:14 PM
04/18/18 12:14 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Re: Anyone know if there are 340 heat riser kits available? [Re: chrisf] #2484790
04/18/18 08:36 PM
04/18/18 08:36 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Hard to find the earlier ones with the thin damper as seen in the top in the pictures.
All the new repros have the fat damper...not sure if the numbers are cast into it like originals
Re: Anyone know if there are 340 heat riser kits available? [Re: vinnyd76] #2485454
04/20/18 06:17 AM
04/20/18 06:17 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's an original thin damper on a 10/15/68 manifold. It looks to be an iron casting. Or it could be a steel casting.
Re: Anyone know if there are 340 heat riser kits available? [Re: kentj340] #2485457
04/20/18 06:25 AM
04/20/18 06:25 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's an NOS replacement thick damper. It looks to be a precision powdered iron pressing. It's magnetic. Maybe the reason for high precision was to get the center hole to the correct press fit diameter without machining? Even the numbers and the pentastar are precision.
11 Exhaust manifold R heat riser showing NOS replacement.jpg11 Exhaust manifold R heat riser showing NOS replacement1.jpg
Re: Anyone know if there are 340 heat riser kits available? [Re: kentj340] #2486048
04/21/18 01:20 PM
04/21/18 01:20 PM
New York
rarefish Offline
rarefish  Offline
New York
Here is a couple of pictures of the thin one from my 69 Dart. Original condition still wearing the factory turquoises engine paint.
