A body offset master cylinder #2483735
04/16/18 05:34 PM
04/16/18 05:34 PM
nj
JAMESDART Offline OP
nj
What pushrod do you use with the 2 bolt offset master cylinder adapter on an a body?
Re: A body offset master cylinder [Re: JAMESDART] #2484320
04/17/18 06:37 PM
04/17/18 06:37 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Went with the adjustable rod from Mancinni Racing.Had to grind a little on the bracket under the dash for clearance, the rod was rubbing on the inside surface because of the offset.
Re: A body offset master cylinder [Re: JAMESDART] #2484328
04/17/18 06:54 PM
04/17/18 06:54 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I just bought the whole shebang from Dr. Diff.. http://www.doctordiff.com/offset-master-cylinder-adapter.html
Re: A body offset master cylinder [Re: JAMESDART] #2484331
04/17/18 06:59 PM
04/17/18 06:59 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I cut my original one and put a sleeve over the cut and welded it back up
Re: A body offset master cylinder [Re: JAMESDART] #2484333
04/17/18 07:05 PM
04/17/18 07:05 PM
nj
nj
I bought the whole shebang also, but there isn't enough room on the left side for the pushrod. He emailed me back saying a lot of the time you have to mill the pedal arm down. I never heard guys having to do that. Figured I'd ask what other evolutionary came up with.
Re: A body offset master cylinder [Re: JAMESDART] #2484396
04/17/18 09:59 PM
04/17/18 09:59 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
This is the one I bought but I have not installed it
http://www.manciniracing.com/ofadforlamom2.html
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: A body offset master cylinder [Re: JAMESDART] #2484434
04/17/18 11:41 PM
04/17/18 11:41 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I installed one in my '69 Valiant without modification.
If your brake pedal measures much over 1/4" thick at the top, you must spot face it around the pivot hole in a mill for push-rod clearance, however.
Cass
