Re: Drilling leaf springs
[Re: mopar dave]
#2484109
04/17/18 11:04 AM
04/17/18 11:04 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Is it solid front bushings/aluminum?? Could you have one machined offset?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Clanton]
#2484115
04/17/18 11:14 AM
04/17/18 11:14 AM
6bblFLASH
N.E. Ohio
Do you use an aluminum sleeve in the front spring eye?Offset drill it. N.E Ohio group logic!! LOL
[Re: 6bblFLASH]
#2484123
04/17/18 11:29 AM
04/17/18 11:29 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Do you use an aluminum sleeve in the front spring eye?Offset drill it. N.E Ohio group logic!! LOL Whew ok I thought it was just me.lol
[Re: 67_Satellite]
#2484148
04/17/18 12:13 PM
04/17/18 12:13 PM
Posts: 4,689 Wichita
GY3
Wichita
I just moved the hole the locating pin sits in. Ditto.
[Re: mopar dave]
#2484158
04/17/18 12:31 PM
04/17/18 12:31 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Yeah if you need to drill another hole in the perch, not the spring.
68 Barracuda Formula S 340
[Re: mopar dave]
#2484236
04/17/18 02:52 PM
04/17/18 02:52 PM
Posts: 860 lancaster,california
johnnycuda
If the car has CalTracs, you may run out of link bar adjustment, also the transmission yoke may not engage the trans enough if the rear is moved back.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: mopar dave]
#2484266
04/17/18 04:09 PM
04/17/18 04:09 PM
Clanton
northern,Ohio,USA
I dont think the link bars will be an issue, but the yoke might as its already out further than recommend. Whats the recommended? 3/4"? I think mines currently 1". Will have to remeasure everything. Good call. Thanks Good time to come out with the u-joint spacer 1/2" lol just kidding.The brake hose may be short,The axle twist may hit the shock,Drive shaft may be too short.Nothing simple.
[Re: mopar dave]
#2484267
04/17/18 04:10 PM
04/17/18 04:10 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
By the way, leveraging the question, I've received my brand new monoleafs from Calvert but currently I'm running with Assassin Traction Bars that require drill a 5/16 hole at leafspring to attach the front link of the bar.
Question: Some problem to drill this hole in the front segment of leaf spring?
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
