Page 1 of 6 1 2 3 4 5 6
Drilling leaf springs #2484080
04/17/18 10:07 AM
04/17/18 10:07 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Think there would be any issues with drilling my Cal vert monos? I need to slide the axle back to center the tire in the wheel well and i need the clearance for the bigger tire. Instead of buying another pair of front halfs, why couldn't i just drill another hole where it needs to be? Looks like the new hole would need to be drilled about 1/2" back from the other. I talked to cal vert about this a few years ago and they were totally against it, but i'm sure they don't want the liability. Thanks
Re: Drilling leaf springs [Re: mopar dave] #2484103
04/17/18 10:50 AM
04/17/18 10:50 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Use a 1/2" spacer in front of the spring eye mount,I did.
Re: Drilling leaf springs [Re: Clanton] #2484106
04/17/18 10:58 AM
04/17/18 10:58 AM
Mt Morris Michigan
Mt Morris Michigan
Thats a great idea, but mine are moved in and welded. Gonna have to replace or redrill front section.
Re: Drilling leaf springs [Re: mopar dave] #2484109
04/17/18 11:04 AM
04/17/18 11:04 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Is it solid front bushings/aluminum??
Could you have one machined offset?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Drilling leaf springs [Re: mopar dave] #2484110
04/17/18 11:05 AM
04/17/18 11:05 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you use an aluminum sleeve in the front spring eye?Offset drill it.
Re: Drilling leaf springs [Re: Clanton] #2484115
04/17/18 11:14 AM
04/17/18 11:14 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
N.E Ohio group logic!! LOL
Re: Drilling leaf springs [Re: 6bblFLASH] #2484123
04/17/18 11:29 AM
04/17/18 11:29 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Whew ok I thought it was just me.lol
Re: Drilling leaf springs [Re: mopar dave] #2484143
04/17/18 12:06 PM
04/17/18 12:06 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I just moved the hole the locating pin sits in.
Re: Drilling leaf springs [Re: mopar dave] #2484147
04/17/18 12:12 PM
04/17/18 12:12 PM
P
Porter67 Offline
Porter67  Offline
P
My calvert springs had a second hole about a inch apart when I removed there two spring clamps to paint them which let me move the axle an inch and cheat on the wheelbase.
If they can sell them with a extra hole, why cant you drill one?
Re: Drilling leaf springs [Re: 67_Satellite] #2484148
04/17/18 12:13 PM
04/17/18 12:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Ditto.
'63 Dodge 330
11.19 @ 121 mph
Re: Drilling leaf springs [Re: mopar dave] #2484158
04/17/18 12:31 PM
04/17/18 12:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah if you need to drill another hole in the perch, not the spring.
68 Barracuda Formula S 340
Re: Drilling leaf springs [Re: 67_Satellite] #2484180
04/17/18 12:55 PM
04/17/18 12:55 PM
Mt Morris Michigan
Mt Morris Michigan
Yep, thats all i want to do without risk of the spring breaking. Yes, aluminum bushings. It would be easier to redrill the spring locating hole.
Re: Drilling leaf springs [Re: Bad340fish] #2484183
04/17/18 12:58 PM
04/17/18 12:58 PM
Mt Morris Michigan
Mt Morris Michigan
Didn't think about that. Guess i could drill the perch instead.
Re: Drilling leaf springs [Re: Porter67] #2484184
04/17/18 01:00 PM
04/17/18 01:00 PM
Mt Morris Michigan
Mt Morris Michigan
I don't think they want the holes too close together, but whats too close?
Re: Drilling leaf springs [Re: mopar dave] #2484236
04/17/18 02:52 PM
04/17/18 02:52 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
If the car has CalTracs, you may run out of link bar adjustment, also the transmission yoke may not engage the trans enough if the rear is moved back.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Drilling leaf springs [Re: johnnycuda] #2484247
04/17/18 03:12 PM
04/17/18 03:12 PM
Mt Morris Michigan
Mt Morris Michigan
I dont think the link bars will be an issue, but the yoke might as its already out further than recommend. Whats the recommended? 3/4"? I think mines currently 1". Will have to remeasure everything. Good call. Thanks
Re: Drilling leaf springs [Re: mopar dave] #2484266
04/17/18 04:09 PM
04/17/18 04:09 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Good time to come out with the u-joint spacer 1/2" lol just kidding.The brake hose may be short,The axle twist may hit the shock,Drive shaft may be too short.Nothing simple.
Re: Drilling leaf springs [Re: mopar dave] #2484267
04/17/18 04:10 PM
04/17/18 04:10 PM
Gravataí, RS, Brazil
360tripleblack77 Offline
By the way, leveraging the question, I've received my brand new monoleafs from Calvert but currently I'm running with Assassin Traction Bars that require drill a 5/16 hole at leafspring to attach the front link of the bar.
Question: Some problem to drill this hole in the front segment of leaf spring?
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Drilling leaf springs [Re: 360tripleblack77] #2484268
04/17/18 04:15 PM
04/17/18 04:15 PM
Mt Morris Michigan
Mt Morris Michigan
Looks like its a non issue if you have no hole in them. I think cal vert frowns on having 2 holes close together. What is too close i dont know, but sounds like 1" apart is fine.
Re: Drilling leaf springs [Re: mopar dave] #2484275
04/17/18 04:37 PM
04/17/18 04:37 PM
Thanks Dave!
Best 1/8 mile ET
