Re: Anyone know if there are 340 heat riser kits available?
[Re: vinnyd76]
#2485454
04/20/18 06:17 AM
04/20/18 06:17 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Here's an original thin damper on a 10/15/68 manifold. It looks to be an iron casting. Or it could be a steel casting.
[Re: kentj340]
#2485457
04/20/18 06:25 AM
04/20/18 06:25 AM
kentj340
Cut and Shoot, TX
Here's an NOS replacement thick damper. It looks to be a precision powdered iron pressing. It's magnetic. Maybe the reason for high precision was to get the center hole to the correct press fit diameter without machining? Even the numbers and the pentastar are precision.
