340 Forged Crank Identification Required... #2483926
04/16/18 10:48 PM
04/16/18 10:48 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I need some help confirming that this is a forged crank for a 340. It's tough to make out the numbers, so I'm hoping the Moparts community can identify this one. It appears to have a wide parting line. The crank makes a ringing sound (but the casting numbers look like they start with 265, which I did not think made sense for a forged).
Re: 340 Forged Crank Identification Required... [Re: vinnyd76] #2483942
04/16/18 11:24 PM
04/16/18 11:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I thought forged 340 cranks had ~1" hole thru some of the throws? shruggy
Re: 340 Forged Crank Identification Required... [Re: vinnyd76] #2483945
04/16/18 11:28 PM
04/16/18 11:28 PM
P
Porter67 Offline
Porter67  Offline
P
Is the converter hub area the same as the newer la cranks?
Could be like my 318-3 truck crank that dont have the counterweights drilled.
Re: 340 Forged Crank Identification Required... [Re: 6bblgt] #2483946
04/16/18 11:29 PM
04/16/18 11:29 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the FORGING number on a 340 crank should be 2843868
a prior 340 forged crank ID thread on MOPARTS
Re: 340 Forged Crank Identification Required... [Re: vinnyd76] #2484035
04/17/18 03:42 AM
04/17/18 03:42 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
That is a 273 or 318 steel crankshaft. 340 cranks have a lightening hole in the #1 and#4 rod pin. With a lighter piston they will balance with no problem.. Just as strong or stronger than a 340 crank.
Re: 340 Forged Crank Identification Required... [Re: vinnyd76] #2484118
04/17/18 11:19 AM
04/17/18 11:19 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
The holes in the rod pins can be added without a lot of difficulty.
