OEM 340 forged crank identification ??? #1511470
10/02/13 02:17 PM
10/02/13 02:17 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I am looking on the internet to get a 3.31 stroke forged crank for my next engine build
I found out that the small mopar forged crank casting numbers are 2532457, 2128869, 2205700 or 2843868; service part number, 2843868
http://www.moparchat.com/forums/showthread.php?t=87974
http://www.forabodiesonly.com/mopar/showthread.php?p=1969562721
http://www.mopar1.us/casting.html
Where is the number located on the crank?
I do know that forged cranks have a wider parting line than a cast crank.
I also know the rods are 2.125" and the mains are 2.50".
273's, 318's and 340's have same stroke
How exactly do I measure the 3.31" stroke?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511471
10/02/13 02:24 PM
10/02/13 02:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I found out that the small mopar forged crank casting numbers are .....
FYI: forged crankshafts DO NOT have casting numbers.
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511472
10/02/13 02:28 PM
10/02/13 02:28 PM
NY NY
3
340duster340 Offline
NY NY
I have a 273 with the pan off I'll take a pics so you have a positive ID
if it came out of 273/318/340 than its a stock stroke crank, all of these are neutral balance, so look at. the balancer and crank weights to tell what you have, to measure you'll need the distance from crank centerline to rod journal center line.
Re: OEM 340 forged crank identification ??? [Re: 340duster340] #1511473
10/02/13 02:59 PM
10/02/13 02:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a "2532457" 273/318 crank. Other numbers may not be in the same location.
Re: OEM 340 forged crank identification ??? [Re: 6bblgt] #1511474
10/02/13 03:26 PM
10/02/13 03:26 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Wait, the pic you posted has a casting number and wide parting line to show its a forged crank, what did you mean by not having a casting number?
Also aren't 2532457 cranks from 340's?
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511475
10/02/13 03:38 PM
10/02/13 03:38 PM
dogdays Offline
dogdays  Offline
IT'S A FORGING NUMBER, !@#$%!.
Forgings have forging numbers, castings have casting numbers.
Castings have square corners and sometimes have surfaces which are rough, as-cast. Forgings have more organic shapes, think of kidney beans.
The only difference between a 273/318 forged crank and a 340 forged crank, is the 340 forged crank has some material drilled out of the #1 and #4 crank throws to balance the heavier pistons used by 340s. You can't tell any difference by the forging number.
R.
Re: OEM 340 forged crank identification ??? [Re: dogdays] #1511476
10/02/13 03:41 PM
10/02/13 03:41 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Oh ok, I never knew about forging numbers!
Thanks for the info!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511477
10/02/13 05:05 PM
10/02/13 05:05 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Anybody have any luck with re-manufactured cranks?
Are the crankshafts from O Reilly's and Autozone junk?
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511478
10/02/13 05:45 PM
10/02/13 05:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
340 cranks 73 on the left and 71 forged on the right.
Re: OEM 340 forged crank identification ??? [Re: RylisPro] #1511479
10/03/13 06:52 AM
10/03/13 06:52 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Be aware that 273 cranks may have a smaller torq converter registering hole in them. You don't want to find that out after assembly!!!!
Re: OEM 340 forged crank identification ??? [Re: 3ddart] #1511480
10/04/13 07:32 AM
10/04/13 07:32 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
^^^^^^^^^^^^^^^^What he said^^^^^^^^^^^^^^
There is nothing wrong with using a 273 forged shaft buy make damn sure you have the back of it drilled out to fit the later converters. I'd rather not discuss just how I acquired this information..
...FAFO...
