Re: cometics and torquing the heads SBM
[Re: Moparnut426]
#2484433
04/17/18 11:40 PM
04/17/18 11:40 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
honestly don't remember anything out of the norm, but here's a bump
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Moparnut426]
#2484474
04/18/18 01:56 AM
04/18/18 01:56 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
ARP has the spec for the bolts
[Re: FastmOp]
#2484481
04/18/18 02:22 AM
04/18/18 02:22 AM
Posts: 4,669 Wichita
GY3
Wichita
I use the fastener mfg. specs and torque them in 3 equal steps.
[Re: Moparnut426]
#2484482
04/18/18 02:27 AM
04/18/18 02:27 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If you Google ARP torque specs , it list torque specs for each size and rating of their bolts and studs. Also if you Google Cometic gaskets it says to torque to the bolt or stud specs. in proper torque pattern.
[Re: Moparnut426]
#2484526
04/18/18 10:41 AM
04/18/18 10:41 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Is there any special torque spec for the SBM using ARP bolts with aluminum heads? I torqued them down to 110lb ft with the old felpro gaskets, but after I went through the engine this winter I cant seem to find the spec. I haven't seen anything on Cometics web site either. check should be whatever the Machine Shop used on the torque plate typically the gasket manufacturer will not recommend a torque spec that would be The Machinist
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
