Whats The Best Way To Clean Off Gasket Material #248334
03/09/09 10:45 AM
03/09/09 10:45 AM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
I'm doing a gasket overhaul on my 383,using steel gaskets for the heads. Whats the best thing to use to get the gasket material off. I have a scraper for the bulk,how do I get them clean like a shop would? I do have a drill if there is something I can get for it. Thanks all.
'71 383HP FJ6 Charger SE
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248335
03/09/09 10:58 AM
03/09/09 10:58 AM
permatex's spray on gasket remover works fairly well on baked on material if you let it set for ~ 10 minutes before you start scraping. I touch up my gasket scraper on the bench grinder & keep the angle right so not to gouge the metal.
Re: Whats The Best Way To Clean Off Gasket Material [Re: RapidRobert] #248336
03/09/09 11:06 AM
03/09/09 11:06 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
have a friend do it.... i really hate scraping gaskets.
One of those spongie fibery looking disk thingies takes gaskets off pretty well without damaging to surface
Re: Whats The Best Way To Clean Off Gasket Material [Re: aarcuda] #248337
03/09/09 11:10 AM
03/09/09 11:10 AM
NE Ohio
NE Ohio
Me too,but my friend is a dick!
I'll see what Harbor Freight has,thanks!
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248338
03/09/09 11:15 AM
03/09/09 11:15 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Napa has a 'scotch brite pad on a drill' that works well, as long as you take it slow and don't get too aggressive. Probably what aarcuda was thinking.
-Dave
Re: Whats The Best Way To Clean Off Gasket Material [Re: hooziewhatsit] #248339
03/09/09 11:28 AM
03/09/09 11:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
-Dave
One needs to be VERY careful using those things , they can and will remove metal , DON'T use them on head and block mating surfaces .
Re: Whats The Best Way To Clean Off Gasket Material [Re: JohnRR] #248340
03/09/09 11:43 AM
03/09/09 11:43 AM
NE Ohio
NE Ohio
What about gasket remover,let it sit,then a scraper then steel wool?
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248341
03/09/09 11:49 AM
03/09/09 11:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no steel wool
what surfaces are you trying to clean ? it doesn't need to be bright and shiney , just down to metal and FLAT ... unless its pitted from rust ...
Re: Whats The Best Way To Clean Off Gasket Material [Re: JohnRR] #248342
03/09/09 12:12 PM
03/09/09 12:12 PM
NE Ohio
NE Ohio
OK cool.Yes, I'm doin the heads and block.
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248343
03/09/09 12:14 PM
03/09/09 12:14 PM
NE Ohio
NE Ohio
no pits
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248344
03/09/09 12:19 PM
03/09/09 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Personally I wouldn't use electric powered stuff on the head gasket surface or the intake surface of the head . It's a crappy job but you don't want to rush it .
Re: Whats The Best Way To Clean Off Gasket Material [Re: JohnRR] #248345
03/09/09 12:28 PM
03/09/09 12:28 PM
NE Ohio
NE Ohio
I got time. Looks likegasket remover and a scraper. Thanks man!
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248346
03/09/09 01:01 PM
03/09/09 01:01 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
"Gasket remover spray" I bought a can. It works. Its actually methylene chloride which is paint stripper and is a carcinogen. Worst part about working on a car is cleaning parts and worst part about cleaning parts is scraping gaskets.
I use different scrapers depending on what and where... Single edge razor scraper. Harbor freight has boxes of 50 or 100 blades cheap. Cheapo Harbor Freight wood chisels. Regular Red devil type spatulas and scrapers. etc etc.
What I won't use is steel wool, sandpaper, garnet paper, aluminum oxide paper, emery paper/cloth etc, scotch bright or any other abrasive substance, by hand or power.
Have to be very careful, especially around aluminum so you don't scratch, gouge, knick, wear away, etc.
Years ago when I was kid I read a book about European racing cars and it mentioned that the place they were talking about in the chapter Ferrari I think forbid using rags for cleaning. Brushes only allowed; no chances for lint plugging up passages/lines/orifices etcetc...
My $0.02
Re: Whats The Best Way To Clean Off Gasket Material [Re: DZJim] #248347
03/09/09 02:15 PM
03/09/09 02:15 PM
My $0.02
Also, when scraping, "visuallyize" how the pressure works in the area you are working, and scrape AROUND the cavitiy, not radially I.E. straight in/ out. In other words, such as a head gasket, you don't want scratches from the scraper pointing into the cylinder area like clock hands. On things like the oil pan rail or timing cover, this is pretty much intuitive. Just scrape the "long way" around
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248348
03/09/09 03:28 PM
03/09/09 03:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I found a razor blade to work quite well.
Re: Whats The Best Way To Clean Off Gasket Material [Re: DaytonaTurbo] #248349
03/09/09 08:34 PM
03/09/09 08:34 PM
Ohio
Strongbad Offline
Bashes Buffoons
Strongbad  Offline
Bashes Buffoons
Ohio
5 bucks for a can of gasket remover spary at most auto parts store is all you need. i asked this question about 2 weeks back and then went and got some and it made life easy.
Re: Whats The Best Way To Clean Off Gasket Material [Re: DZJim] #248350
03/09/09 09:21 PM
03/09/09 09:21 PM
My $0.02
I remember reading once that German mechanics are not allowed to have hammers in their toolboxes as the shop foremans philosophy is that parts should be made to fit without the use of brute force
Re: Whats The Best Way To Clean Off Gasket Material [Re: RapidRobert] #248351
03/09/09 10:12 PM
03/09/09 10:12 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
My $0.02
true story. the first motor i ever rebuilt was cleaned using brake cleaner to remove the grease and towels to wipe down
it look perfect.
during the cam break in the oil pressure went from 65 psi down to 15 or so in about 5- 10 minutes.
I puled the motor out thinking i did serious damage. as soon as i pulled the pan i saw the problem. The oil pickup screen looked like a dryer lint filter- completely covered with the lint from my towels.
So yes, that lint statement is very true. it happened to me
Re: Whats The Best Way To Clean Off Gasket Material [Re: aarcuda] #248352
03/09/09 10:50 PM
03/09/09 10:50 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Mopar recommends this on aluminum heads.
They are called Roloc discs and made by 3M.
Re: Whats The Best Way To Clean Off Gasket Material [Re: 375inStroke] #248353
03/09/09 11:22 PM
03/09/09 11:22 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Hmmm... Abrasive...aluminum oxide mds here
I guess if MOPAR says OK; however...
