Re: Whats The Best Way To Clean Off Gasket Material
[Re: 71 FJ6 Charger]
#248335
03/09/09 10:58 AM
03/09/09 10:58 AM
RapidRobert
permatex's spray on gasket remover works fairly well on baked on material if you let it set for ~ 10 minutes before you start scraping. I touch up my gasket scraper on the bench grinder & keep the angle right so not to gouge the metal.
[Re: aarcuda]
#248337
03/09/09 11:10 AM
03/09/09 11:10 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Me too,but my friend is a dick! I'll see what Harbor Freight has,thanks!
'71 383HP FJ6 Charger SE
#248338
03/09/09 11:15 AM
03/09/09 11:15 AM
Posts: 3,903 Oregon
hooziewhatsit
Napa has a 'scotch brite pad on a drill' that works well, as long as you take it slow and don't get too aggressive. Probably what aarcuda was thinking.
-Dave
[Re: hooziewhatsit]
#248339
03/09/09 11:28 AM
03/09/09 11:28 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
-Dave
One needs to be VERY careful using those things , they can and will remove metal , DON'T use them on head and block mating surfaces .
[Re: JohnRR]
#248340
03/09/09 11:43 AM
03/09/09 11:43 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
What about gasket remover,let it sit,then a scraper then steel wool?
[Re: JohnRR]
#248342
03/09/09 12:12 PM
03/09/09 12:12 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
OK cool.Yes, I'm doin the heads and block.
#248346
03/09/09 01:01 PM
03/09/09 01:01 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
I'm doing a gasket overhaul on my 383,using steel gaskets for the heads. Whats the best thing to use to get the gasket material off. I have a scraper for the bulk,how do I get them clean like a shop would? I do have a drill if there is something I can get for it. Thanks all.
"Gasket remover spray" I bought a can. It works. Its actually methylene chloride which is paint stripper and is a carcinogen. Worst part about working on a car is cleaning parts and worst part about cleaning parts is scraping gaskets.
I use different scrapers depending on what and where... Single edge razor scraper. Harbor freight has boxes of 50 or 100 blades cheap. Cheapo Harbor Freight wood chisels. Regular Red devil type spatulas and scrapers. etc etc.
What I won't use is steel wool, sandpaper, garnet paper, aluminum oxide paper, emery paper/cloth etc, scotch bright or any other abrasive substance, by hand or power.
Have to be very careful, especially around aluminum so you don't scratch, gouge, knick, wear away, etc.
Years ago when I was kid I read a book about European racing cars and it mentioned that the place they were talking about in the chapter Ferrari I think forbid using rags for cleaning. Brushes only allowed; no chances for lint plugging up passages/lines/orifices etcetc...
My $0.02
[Re: DZJim]
#248347
03/09/09 02:15 PM
03/09/09 02:15 PM
My $0.02
Also, when scraping, "visuallyize" how the pressure works in the area you are working, and scrape AROUND the cavitiy, not radially I.E. straight in/ out. In other words, such as a head gasket, you don't want scratches from the scraper pointing into the cylinder area like clock hands. On things like the oil pan rail or timing cover, this is pretty much intuitive. Just scrape the "long way" around
[Re: RapidRobert]
#248351
03/09/09 10:12 PM
03/09/09 10:12 PM
Posts: 15,491 the boonies
aarcuda
the boonies
Years ago when I was kid I read a book about European racing cars and it mentioned that the place they were talking about in the chapter Ferrari I think forbid using rags for cleaning. Brushes only allowed; no chances for lint plugging up passages/lines/orifices etcetc... My $0.02
I remember reading once that German mechanics are not allowed to have hammers in their toolboxes as the shop foremans philosophy is that parts should be made to fit without the use of brute force
true story. the first motor i ever rebuilt was cleaned using brake cleaner to remove the grease and towels to wipe down
it look perfect.
during the cam break in the oil pressure went from 65 psi down to 15 or so in about 5- 10 minutes.
I puled the motor out thinking i did serious damage. as soon as i pulled the pan i saw the problem. The oil pickup screen looked like a dryer lint filter- completely covered with the lint from my towels.
So yes, that lint statement is very true. it happened to me
[Re: 375inStroke]
#248353
03/09/09 11:22 PM
03/09/09 11:22 PM
DZJim
DuPont, Washington
Mopar recommends this on aluminum heads.
They are called Roloc discs and made by 3M.
Hmmm... Abrasive...aluminum oxide mds here
I guess if MOPAR says OK; however...
